Miniram an upgrade?
Old Jun 9, 2006 | 01:00 AM
MaxLean's Avatar
Miniram an upgrade?
I have the oppertunity to try out a miniram on my 383 LT1 and was wondering if it would yield any improvements. It was on a blown SBC and oddly enough, it's also drilled with the LT1 pattern! The angle is wrong but slotted so some type of angled wedge will be needed under the bolts. Anyway, my car is a '94 383 with early AFR heads (twice ported, 260cfm, 199/cfm @.5". The cam is a solid roller CC 242,248 610",615 w/1.6. 1 3/4" headers, dual 3" exhaust through mufflers. There is more, but that should be whats important. Currently it runs a best of 11.42@125.3 on drag radials with a 1.72 best 60'. I know I'm limited by the LT1 intake and a single plane is the way to go (or sheet metal). The miniram appears to have a larger plenum and better runner shape/angle. The miniram is ported to my gasket size too. The question is: would this be an upgrade, and if so how much of the way to a single plane is this move? And does anyone know where to get the angled wedges?
Old Jun 9, 2006 | 05:01 AM
LameRandomName's Avatar
Re: Miniram an upgrade?
I would argue that you have a sort of an obligation to test this question; being that the opportunity has presented itself.
Old Jun 9, 2006 | 10:25 AM
SStrokerAce's Avatar
agreed
We can give you all the educated guesses you want but you have the ability to find the proof without spending too much coin.
Bret
Old Jun 9, 2006 | 02:01 PM
MaxLean's Avatar
Any ideas on what to do about the different angle of the intake bolts? Are there angled wedges available for this? I could probably call TPIS, but I don't particularly like them... By the way, this manifold comes with a monoblade TB That ought to be insteresting.
Old Jun 9, 2006 | 05:09 PM
thesoundandthefury's Avatar
You'll need a 7/8" counterbore. It looks like this:
Best way to do it is with the intake on the motor, and with a long bolt screwed into the adjacent mounting hole from the one you're boring that will give you a point of reference from which you can "eyeball" what angle to have your grinder tilted at. These things go through aluminum like a hot knife through butter so use a light touch with low tool speed.
Old Jun 9, 2006 | 07:49 PM
MaxLean's Avatar
Can't really modify the intake at the moment as I'm just "testing" it. Any other ideas?
Old Jun 9, 2006 | 08:15 PM
mw's Avatar
mw
http://www.flatlanderracing.com/powe...cessories.html
Maybe you could make these work.
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
