advice on vic jr to lt1 swap
Old May 30, 2006 | 09:56 PM
wes302's Avatar
putting a victor jr (carb)on my lt1. any advice on how to drill new holes or any general info on swap
Old May 30, 2006 | 10:01 PM
1racerdude's Avatar
Re: advice on vic jr to lt1 swap
A good machine shop can pattern and drill the holes.
If ya got a stroker and heads and cam the Super Victor is the way to go.
Get in touch with Bauer Racing as they are/were building a set up for the LT1 either carb or EFI.
Old May 30, 2006 | 10:08 PM
BADST95's Avatar
Thumbs up Re: advice on vic jr to lt1 swap
Any reputable engine builder can machine the intake for you.
Old May 30, 2006 | 11:23 PM
wes302's Avatar
that is a sweet ride!!!!!!!!!
Old May 31, 2006 | 01:03 AM
lt1camaroman93's Avatar
I had a local machine shop convert mine over.
Old May 31, 2006 | 01:22 AM
atljar's Avatar
I did mine myself with a level and a drill press.
Old May 31, 2006 | 09:29 AM
BADST95's Avatar
Thanks! Wanna buy it?
Old Jun 5, 2006 | 08:36 AM
CR0067's Avatar
I am currently doing the same thing with an old torker intake! I was going to use a gen1 350, but I have 2 lt1 blocks laying around one is a complete lt1 from a 95 caprice police car and I have a new set of aluminum heads (lt1).The benefits of the aluminum heads and roller cam setup are hard to pass up! I know some of the bolt holes are going to have to be modified but a question(s) I have is do the runners line up and does the manifold mate flush to the cylinder heads when they`re on the block! Also is the distributor hole lined up with the cam gear in the rear, or can the optispark be used at all on a carb setup without use of the pcm. P.S. I`m building a junkyard turbo setup for a 4th gen camaro and if this works good I will go with a super victor for upper rpm capability.
Old Jun 6, 2006 | 09:37 AM
wes302's Avatar
well i drilled my intake for the lt1 (victor jr) wow what a PITA. IF YOU HAVE THE MONEY SEND IT OUT TO BE DONE. going to be using some jb weld today to make it look a little better and buy 4 studs for the middle bolt holes.
ports were not that bad lining up. i mocked this up on an old lt1 block and heads out of the car. with my ported heads the intake will be perfect.
Old Jun 6, 2006 | 11:11 PM
1_bad t/a's Avatar
FWIW: look for a member in here his name is 96speed hes got one for sell.
Old Jun 6, 2006 | 11:23 PM
atljar's Avatar
Ya thats the more difficult approach because the center runners get in the way of the bolts. The easier way is to modify the lt1 heads to accept the SBC bolt pattern.
rocketman051894
Jan 30, 2015 03:23 PM
chuyz28
Nov 25, 2014 11:14 PM
smacz28
Aug 6, 2002 01:51 PM
squinn
Aug 4, 2002 01:06 PM
