Disabling FPSS…
Old Aug 23, 2003 | 02:48 AM
craigffb's Avatar
Disabling FPSS…
How can I disable my FPSS? I have it wired up and it’s been working fine up to this point, and still maybe. But last week I took my bottle to get filled and made one run and everything was fine, then on the very next run it was sputtering like the bottle was empty already. I checked all my connection and can’t find any leaks so if it’s not the FPSS, the place that filled my bottle shafted me on the fill.
Nitrous install
Old Aug 23, 2003 | 03:43 AM
sssalah's Avatar
A jumper wire over the 2 connections of the fpss should do it.
Old Aug 23, 2003 | 03:52 AM
craigffb's Avatar
Could I just unscrew them from the FPSS and use a small nut to connect the wires at the eyes?
Old Aug 23, 2003 | 11:47 AM
LPEdave's Avatar
Sure.
Old Aug 24, 2003 | 12:21 PM
11 sec gta's Avatar
Either use a jumper over the FPSS or bypass it altogether.
On the ground side of the relay (either 85 or 86) just go straight to a chassis ground instead of to the FPSS, then to a ground.
68camaroboltz
Oct 5, 2015 01:46 PM
95_lt1_z28
Aug 30, 2015 06:17 PM
Aug 7, 2015 08:52 AM
MichiganSkip
Aug 6, 2015 09:38 AM
TEAL94Z28
N2O Tech
Nov 4, 2002 02:25 PM
