heads and cam plus nitrous questions
Yes, it seems to be hit and miss with the fragility of the hypereutechtic threshold. Maybe it has to do with the mix or porosity. Some cars can go up on the spray, while most can't pass 150 before crushing a ring land.
If you've got heads and cam, you've probably had programming done. If so, it sounds like the spark advance in addition to the N2O would create a bit of knock. You can do several things:
- Use race fuel (unleaded or you'll toast your O2s)
- Add a race fuel auxilary tank
- Reprogram to retard timing 2-3* degrees
- Add a timing retard controller to the interior
- Richen the mixture with a larger fuel jet
You may be starving the system too with 150 shots... may need to upgrade the fuel pump. You're at that threshold.
oldschool
Feb 9, 2016 09:21 PM
