??need special engine assembly procedure for N20??
Old Aug 25, 2003 | 09:12 PM
charles94ta's Avatar
Question ??need special engine assembly procedure for N20??
Hi I rebulding my 96 lt1 block, I will be using 150 shot (for now...) on 383 stocker engine. I am using all new forged parts, block will bve bored 0.030. This engine will be used mostly NA, with regular use of N20. I was wondering if I need to do anything special at assembly time for use with nitrous. What rings and at what gap? Anything else special, thanks for your help.
Old Aug 26, 2003 | 12:55 PM
BILLJ's Avatar
How big of a shot are you planning on bumping up to? For just a 150 the standard ring gap you or you builder where gonna use should be fine. 200 and up I would ask one of your local shops that you plan on a 200+ and would like to know what gaps the prefer to run for max perf or life expectancy. Most good shops would be more then happy to help you. It's there way of gaining your trust and making you a possible return costumer.
DirtyDaveW
Dec 1, 2016 05:37 PM
CARiD
Jan 27, 2015 06:27 AM
Dec 1, 2014 08:08 AM
kizz
25
Aug 2, 2002 08:21 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
