Biggest Shot You Guys Think Is Safe For TR6 Plugs??
I've used a 300 shot with with TR-6s. Seen quite a few 250 shots and countless 100 and 150 shots.
A 300 shot can work with those plugs. Question is - are your pistons, tranny, and rearend up for it???
hehehe thanks
tr6's are good to about 200,sure you could go higher,but why risk it?
at least a tr8 is recommended by a few nitrous guys (Steve Johnson,Jon Phillips) for 200-300 shots and they suggested a colder plug for anything bigger.
NA power shouldnt be much of a concern when you plan on going with a big 400 shot,as everything should be biased for nitrous anyway.
I am using plugs with an "11" heat range and don't have problems with fouling, so I think you can go way colder than a TR6 without a problem. There is nothing special about my igntion system. Opti, MSD6, Accel coil, stock wires.
Rich Krause
Rich Krause
So what was the consensus for running that cold of a plug N/A, is it a bad thing, or not a problem with a good ignition system? Planning on running 250-300 and totally forgot about plugs, dont want to change them out constantly.
Jan 23, 2015 01:13 PM
