ported heads/stock cam/fully forged bottom end??
Old Sep 9, 2003 | 11:43 PM
lt1camaroman93's Avatar
ported heads/stock cam/fully forged bottom end. is it safe to spray a 300 shot through that??? naturaly i will be upgrading the fuel system. I know people are going to say why a stock cam? i am looking for sleeper mode here.
Old Sep 9, 2003 | 11:53 PM
RacinLT1's Avatar
as long as the fuel/ignition system can handle it,sure.
Old Sep 10, 2003 | 02:08 AM
CRCDUDE's Avatar
300 woohoo
WOW 300 is a lot for a small block dont care whats done to it
Not at all sayin it cant be done Just would creep up on it
I would start with some really good fuel say 114 -116 race fuel no airport ****. And some really cold plugs NGK 9 if not a 10
Spark plugs are a hell of a lot cheaper than pistons
Good Luck let us know how it goes.
Old Sep 10, 2003 | 06:05 AM
I'm not 100% sure if this is the route i am going to go, but if so the car wouldn't see lower than 110 fuel. I might wait until next winter to do the engine rebuild and finish setting up the chassis/rear end this winter.
Old Sep 10, 2003 | 11:28 AM
12Second3rdgen's Avatar
A rule of thumb I often hear is not to exceed 50% of the engine output before nitrous. For example, if an engine makes 400 horsepower, then a 200 shot is a reasonable amount of nitrous to run on it all other variables (bottom end, fuel delivery, etc) are all up to par.
Old Sep 11, 2003 | 12:37 AM
Rival's Avatar
you could put something small in and still have it sound stock. Plus you want to rev the motor past 5500rpms right
Old Sep 11, 2003 | 05:59 AM
I just contacte CM to see about a custom nitrous cam that would be next to impossible to hear. We will see what they have to say.
Old Sep 11, 2003 | 10:15 PM
jerrywho's Avatar
300 is no problem on a strong motor. I have a factory stock L98 that has never had the valve covers off and use 200 plus on it. With the 200 shot I get mid 11s with the stock motor.
Jerry
Old Sep 11, 2003 | 11:01 PM
what type of engine did you spray a 400 through?
Old Sep 12, 2003 | 02:53 PM
menlatin's Avatar
uhmm.. dont forget about ring gap. I was told that for a 250-300 shot you need about .030 gap on the top ring. I've got .025 and dont plan to go over a 200 shot.
Old Sep 12, 2003 | 05:44 PM
TMDZ28's Avatar
Originally posted by InjectedSS
stock lt1 dude
lol j/k no i sprayed that on an LT1, well not stock of course... shes got a lil some something inside there
what kind of some something inside you have there brother??
bother to share it with us??
Old Sep 13, 2003 | 07:03 AM
InjectedSS's Avatar
not being a dik but i just don't really like telling anyone. people that i know read this board and then word will get out what's under the hood and that ='s me getting no race's
either way, let's just say this, my ****'s built to do it
when i was running a stock bottom end though, i made sure to have my NGK TR6 plugs gapped at like 0.35, run straight 100 unleaded gas, and i ran about 6* of timing retard...
just play it safe guy's, do what i said above and you can DEFINATELY spray AT LEAST a 200shot on a stock bottom end... DO NOT do it like ALL THE TIME, but you could get away with doing it like 2 or so passes down the track to get a cool timeslip
also what i like to do is CHANGE MY OIL before i go to the track when i knew i was going to be spraying big on a stock bottom end... I still do it now cause it's better to be safe than sorry
Old Sep 13, 2003 | 12:17 PM
TMDZ28's Avatar
i understand.... good luck with your races man...
what about autolite 104's?? i heard they are okay for small shots....i'm running 104s gapped at 0.30, 75 shots, with no timing retard. i thought 150 shot is ok without timing retard
please share your knowledge
Old Sep 13, 2003 | 01:55 PM
currently i am running 150 shot on stock timming, ngk tr6 plug, and 108 fuel. no problems yet.
Old Sep 13, 2003 | 04:26 PM
InjectedSS's Avatar
yea you could get away with no timing retard but dude make sure you run like straight race gas, like some 100 unleaded... the autolites are OK butnn personally i like the NGK's.. although i HAVE used both...
