do i need a strong bottom end or top end for large nitrous??
Old Sep 5, 2003 | 05:50 PM
TMDZ28's Avatar
which one is more important?? beef up my bottom end or my top end?? i'm planning to use forged summit rebuild kit plus forged crankshaft to beef up my bottom end, and LT4 hot cam kit with stage 2 LT1 ported and polished heads for my top end.......which one needs to be stronger?? top end or bottom end....thanks guys
BTW, i'm gonna run mostly 150 nx wet shot, but sometimes i might run 200 shots with race gas, just to win a race
thanks for your input
Old Sep 5, 2003 | 06:26 PM
AutoRoc's Avatar
The bottom end see's all of the power and if it fragments itself you have a big problem on your hands It could possibly take out a nice top end package also!
Go with something more than a Hotcam too please
Old Sep 5, 2003 | 06:34 PM
12Second3rdgen's Avatar
Get a bigger cam, then talk about large doses of nitrous. A lot of stock cams have as much duration @.050 as the LT4 cam does.
Old Sep 5, 2003 | 09:15 PM
RacinLT1's Avatar
DEFINATELY bottom end. as said above that is what takes all the abuse.
Old Sep 5, 2003 | 10:42 PM
TMDZ28's Avatar
do you think summit bottom end rebuild kit is enough?? or should i go with something stronger and more expensive....my budget is only $3500 for everything
also what cams do you guys suggest??
Old Sep 6, 2003 | 04:59 AM
RacinLT1's Avatar
if you are looking for only occasional 200 hp hits,that kit will be fine.
Old Sep 6, 2003 | 11:28 AM
TMDZ28's Avatar
so that kit will be able to handle about 1 bottle a week of 150 - 175 shots of nitrous?? i really wanna make this engine last for a long time though.....i will also upgrade my fuel pump along with my ignition. i'm gonna be putting 255 walbro intank fuel pump, with MSD 6al, with 8.5 msd wires and coil....what do you think??? thanks
Old Sep 7, 2003 | 05:46 AM
RacinLT1's Avatar
my stock parts have lasted a long time with a 150 to 175 shot.
a forged bottom end like that will be fine.
remember,it isnt nitrous that breaks parts,it's a bad tuneup that will break parts.
Old Sep 8, 2003 | 08:42 AM
TMDZ28's Avatar
WOW, that's new to me.....so a good tune up is the key to a long last engine?? sorry to bother again, but do you know where i can get a good tune up??
thanks so much
Old Sep 8, 2003 | 03:52 PM
thanks so much
I think you guys are on two different pages.
He is trying to tell you that it is more often the nitrous tuner's fault for engine failure. Granted nitrous adds a significant amount of cylinder pressure and stress on the bottom end, but he is saying that a properly tuned nitrous system is just as important if not more important than the parts you put below it. Even the best bottom end in the world wont last without fuel .
Old Sep 8, 2003 | 09:21 PM
RacinLT1's Avatar
a good tune up comes from experiance and knowing your limits.
i have been using nitrous on various cars since 94,and it is something you learn.
i wish there was a good place to get a good "tune up" but every car is different as is locations/weather etc. patience leads to good tuneups,as well as knowing how your car reacts to nitrous and how it runs in general.
dont get greedy,that leads to a bad tuneup.
im sure if you went to some of the BIG name nitrous shops like Applied Nitrous Technology,John Phillips from NX,Steve (?) from NOS they can get you on the way to a good tuneup,although at a VERY steep cost wich isnt needed with the smaller style shots we run.
Old Sep 9, 2003 | 01:09 PM
TMDZ28's Avatar
thanks for all the info. i'm learning as we speak.....
is there any tuner sorfware that i can use in order to tune my car?? or tuning in this case is using different jets?? i'm thinking about sending my PCM to PCM for less for a good computer tuning. as far as jet tuning, i will stay with what NX gives me, or maybe a little richer. i would rather go a tad slower, and go a tad faster with a blown engine.....
again, thanks for all the info guys
Old Sep 9, 2003 | 01:17 PM
RacinLT1's Avatar
i am referring to the nitrous tuneup using jets plugs etc.
do NOT go any richer then what they recommend,they run extremely rich as is. my car went flat using NX's recommended jets,but others work fine.
a good computer tune cant hurt,but get the computer programmed for the best NA performance.
as far as software,you can use LT1 edit,but it isnt the easiest thing to figure out. PCM for less or Madwolf would be good choices.
Old Sep 9, 2003 | 07:57 PM
TMDZ28's Avatar
so as far as tuning the jets my self, any advice on how to do this safely?? a friend of mine that installed my kit said that he will tune it for free, but i wonder, why do i need some tuning when NX already provided us with their recommendation.....please elaborate more.....thanks
Old Sep 9, 2003 | 08:12 PM
RacinLT1's Avatar
all nitrous kits sold for the "basic user" are tuned very rich for safety.Manufacturers always go rich to protect the beginner/newbie,better to be fat and slow then to have every average joe breaking parts and giving nitrous a bad rep, if you are happy with what they tell you to use,dont change.
My car and a few friends cars were too rich with the stock jets,and picked up considerably when we started tuning the fuel jets.Reading plugs is KEY here,as they will show the first signs of detonation by appearing "peppered" (you will see small black dots on the porcelin).
currently i run 2 jets leaner on the fuel side on just about every shot i have tried,but that is MY car,others may vary.
If i ran the stock jetting for a 150 shot,it would surge,and almost foul the plugs.
