fuel/ignition requirements?
im thinking about getting a nx wet kit and running a 100 shot. my question is do i need to get a higher flow in-tank fuel pump or inline? or is the stock pump good enough to handle it? also, how about the ignition system, do i need anything or is stock alright?
The NX Stage 1 systems are designed to work with a stock ignition and a stock fuel system although upgraded ones are a definaite plus. If your fuel system and ignition are in good shape you should be fine. A high volume fuel pump is a good insurance policy when using nitrous. I don't sell them but I usually recommend the Walbro 340 which is an excellent pump at a reasonable price. I bought mine from Racetronix who is also an advertiser on this board. You do need to go one or two steps colder on your plugs and don't use platinum plugs.
Let me know what all you would like with your system and I will give you an unbeatable price on a new NX system! Thanks
Aug 24, 2015 06:41 AM
Wilson
Jul 21, 2002 05:08 PM
