Stall converter and nitrous
I have a NX single EFI wet kit and was wondering if i can use it with the stock stall converter. I will be getting a vigilante but it will be a few weeks till i do.
Just make sure you don't hit the nitrous until 3k rpm's or so. If you hit it earlier you have the risk of a backfire. I spray mine out the hole off the converter. I have a 3,600 stall though.
If your new Vigilante is around 3k or more you should be able to juice it out the hole also. Traction permitting.
I sprayed mine out of the whole on my stock stall without any problems but I am not saying you won't I just didn't. I have a 3200 stall now so I dont worroy about it.. And to tell the truth I never worried about it on the stock stall..
Javier97Z28
Sep 8, 2002 07:23 AM
