Best Timing Retard Box??
Old Aug 23, 2003 | 11:23 PM
JuiSSed's Avatar
i need a timing retard box to work with my MSD 6A and MSD window switch.. i need to pull out between 5-6 degrees for my system to work without detonation..
thanks
vinnie
Old Aug 27, 2003 | 12:07 PM
FastZonTNT's Avatar
The TIMING TUNER box is awesome
Old Aug 27, 2003 | 12:09 PM
JuiSSed's Avatar
Timing Tuner?? More info please!
Old Aug 28, 2003 | 08:08 AM
FastZonTNT's Avatar
Do a search for it as TIMING TUNER. Its also a nitrous controller box all in one. It plugs into a few sensors and the crankcase. You can mount it beside your air box and easily adjust timing with turn of a ****. Heres what it doe... advances timing, retards timing when nitrous is activated, built in window switch, and also if you have a superchager it gradually takes timing out rather than all at one time.
Old Aug 28, 2003 | 02:59 PM
Loadre's Avatar
Mallory's Hyfire VI (part #685) is QUITE good. Look it up on jegs.
*Emilia*
May 13, 2015 09:05 AM
mikey4play
Mar 15, 2015 11:45 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
