Need spark plug part #'s for 2-3 steps colder
Old Sep 21, 2003 | 09:31 PM
Nostang 96z's Avatar
I need spark plug part #'s for 2-3 steps colder than stock for either NGK, champion, or Autolite spark plugs. If you can post the brand, part #, and heat range I would appreciate it.
Thanks in advance
Matt
Old Sep 22, 2003 | 07:10 AM
Derrick Redd's Avatar
Autolite 103 = 2 steps cooler
I'm running the 103's. Runs great NA and on the dope.
Old Sep 22, 2003 | 07:58 AM
Thanks for the reply! Are those 2 steps or 3 steps colder? The only reason I ask is because 106's are listed stock and the 103 are 3 steps down from stock.
BTW I found NGK R5724-8 plugs on thunderracing for a 3 step colder than stock plug. Has anyone used these plugs? Experiences with them?
Anyway keep the #'s and suggestions coming. Need the plugs to be good for a 200rwhp hit on top of my 11.5-1 engine.
Thanks again
Matt
Old Sep 22, 2003 | 03:54 PM
Autolite 104 is 1 step colder than stock. 103 is 2 steps colder.
I don't know how many "steps" colder it is, but I use a Champion S57YC for a 275-shot.
Old Sep 22, 2003 | 07:36 PM
Thanks for the reply fred! I'll have to find a set of those plugs and try them out for the big shots
Matt
Old Sep 23, 2003 | 01:30 AM
KTamez's Avatar
When it comes down to it, the options are limitless.
You could also try an NGK R5671A-9 . Depending on the pills you use, you can change the last number higher or lower to change the heat range (Lower number is a hotter plug). 7-11 are available.
Old Sep 23, 2003 | 05:29 AM
Thanks again Kurt. I'll let you know how it turns out. BTW, could you e-mail me that number to the guy you were talking about in the e-mail for jet size analysis?
Matt
Old Sep 24, 2003 | 03:02 AM
KTamez's Avatar
Matt, sending ya some email.......
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
94z28jbw
Sep 8, 2002 03:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
