need help with 100 shot NX wet shot jets
what's the jet size for 100 wet shot, i have an NX kit...thanks...
thinking about upgrading my shots...i'm gonna install my walbro fuel pump too, so 100 shot should be ok right
A nitrous jet of .047" would produce 100 horse based on 1000 psi bottle pressure. Use a fuel jet of .027" based on 40 psi of fuel.
A stock fuel pump could easily handle a 100 shot if you're still reasonably stock.
NX' sheet specifies 52/33 for LT1 and 52/31 for LS1. I've found the 33 fuel jet to run pretty rich on my car so I use 31... even tried 28 and that seemed to be perfect--but then you run the risk of a quick drop in FP and super lean.
No, not for the regular 100-shot, more as a precaution to a dip in FP while spraying.
I mean, with the leaner fuel jet, a dip in FP will make you go leaner, obviously.
I guess it's not much of a difference. I use the 52/31 (and 52/28) in my car with a stock engine and fuel pump, with no probs yet.
Originally posted by TMDZ28
i dont know much about FP
but isnt lean = danger
Different kits use call for different jet sizes for the same hp level. Some are shooting for crank hp, and some for rwhp. Also, different applications run different fuel pressures, so you could see different jet size numbers based on the application. In short, it sounds like the NX kit would actually push a little more power out since they are using a bigger nitrous (and fuel) jet. You could run those jets with no problem.
Originally posted by cjksflorida
Would those jets work for the NOS kit also or is it different, because I'm running 46/30 that I thought was 100 shot. Thanks
Devinfoote87
Jul 30, 2015 09:54 AM
Jul 17, 2015 02:47 PM
