N20 and porting the heads??
Old Sep 10, 2003 | 11:04 PM
JeremyKweens's Avatar
would porting my stock heads be a good idea while running a 100 shot..and if so what flow numbers should I aim for. I would possible install a hotcam aswell
Old Sep 11, 2003 | 12:05 AM
RacinLT1's Avatar
match the cam with the flow numbers.if you want a hotcam get the porter to match them up.
there is no reason to port the heads specifically for nitrous.and even if you were gonna port the heads for nitrous,there are no magical or specific numbers to aim for.
Old Sep 11, 2003 | 09:04 AM
Gripenfelter's Avatar
With a wet kit some people leave the intake part of the head a little rougher than usual when porting to prevent fuel puddling. So maybe a 40 grit instead of an 80 grit?
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
