Brake Fluid
Old Oct 28, 2003 | 02:35 AM
Francis01's Avatar
Brake Fluid
Hi all, I was wondering if any one would have any advice regarding Brake Fluid to use in the 68 Camaro I am rebuilding.
After looking at different tips and links around the place A few people warned against using any Brake Fluid that had Silicon in it, but no one mentioned why.
Thanks for any help you can offer.
Francis
Old Oct 28, 2003 | 06:04 AM
SLO SS K2's Avatar
I believe something is the chemical makeup of it seems to create air in the line. I think the only ADVANTAGE to silicon is that it won't damage paint. If the air thing is correct then you could ruin a lot more than paint with silicon brake fluid. Good old basic Dot 3 or 4 is great.
Old Oct 30, 2003 | 09:02 AM
stale's Avatar
Yeah, brake fluid is brake fluid on those old braking systems. I think I'm running some "Road & Track" DOT 3. If you've got the good ol' trusty 4-way drum setup, you're going to have brake fade no matter what
Old Oct 31, 2003 | 11:07 PM
NeverGonnaRun's Avatar
Actually there's no real disadvantage to running a DOT 5 (silicon) set up. It's just that most people drain out their old DOT 3/4 fluid and pour in the DOT 5 and then drive off. Bad idea. DOT 3/4 and DOT 5 DO NOT MIX! You have to VERY thoroughly flush your system with the DOT 5 stuff before you bleed it and drive off. You also have to make absolutely certain there is no water vapor in your lines. So it's really up to you.
Old Nov 3, 2003 | 11:39 PM
pink68's Avatar
DOT 5 also does not absorb water. Thats the reason so many old cylinders are frozen or broken, DOT 3/4 is a water magnet. If your not gonna use the car a bunch (ie. only for cruise nights etc) then DOT 5 is the ticket. I have been using if for a while and have no complaints.
jim
Bobczar
Oct 23, 2015 11:22 AM
spcearle
Jun 26, 2015 01:11 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Death's.Stalker
Feb 26, 2002 12:53 PM
