400sb 2 bolt or 4 bolt??
Old Dec 24, 2003 | 12:42 PM
Daniel Mitchell's Avatar
I assumed that a 4 bolt 400 block would be better than a 2 bolt block but now I've heard that the 2 bolt block is stronger, maybe in the webbing or something like that? Can't really remember. Anyone know anything about it? Thanks.
Old Dec 24, 2003 | 01:08 PM
kacy's Avatar
ive heard that also plus ive also heard that splayed 4 bolt mains are stronger than standard 4 bolts
Old Dec 24, 2003 | 03:09 PM
SDAKOVIC's Avatar
If you ever get a chance to look at a two bolt and a 4 bolt block, look closely at the outer bolt hole in the 4 bolt block and you will see why they are weaker. They really thin out the block material in this area. The only way to get more strength, is to run the splayed outer bolts. By the way i have run 10's on a two bolt block!
Old Dec 24, 2003 | 03:50 PM
Dirt Reynolds's Avatar
I run a 2-bolt 400 block. The 4-bolt is indeed a weaker casting. The outer bolts go into a thin area of the block and actually weaken the casting more than helping it.
The 2-bolt main caps of the 400 are much beefier than the caps for all other small blocks. Put them both side by side and that will become readily apparent. A 2-bolt 400 is a pretty strong piece. I have never seen one break in the cap area in my own experience. The crank is one tough ***** also. As SDAKOVIC posted, a 2-bolt block will make 10-second power without too much trouble.
Old Dec 24, 2003 | 10:13 PM
Thanks for the info guys, I appreciate it!
Old Dec 28, 2003 | 08:52 PM
91 GTA Ramair2's Avatar
Yes yes in 400's use the 2bolt for sure........
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
DETROIT_AREA_00_SS
Aug 21, 2002 06:38 AM
