Price of Labor, Engine Swap?
Old Nov 9, 2003 | 12:19 PM
KC-71's Avatar
Around what price is it for labor on an Engine Swap? (ZZ4 350 crate). Thanks.
Old Nov 9, 2003 | 01:32 PM
Greed4Speed's Avatar
Call a local place. Thats how I find out prices.
Old Nov 9, 2003 | 02:17 PM
Erik's Avatar
Classic Tech Moderator
Having never done anything more indepth than a carb swap, I managed a ZZ4 + HOT cam swap almost entirely by myself in my garage. All I needed was to borrow an engine hoist (the could probably be rented) and to buy a couple of tools - harmonic ballancer puller, distributor wrench (for removing motor mounts), a valve spring compressor (I needed to install the HOT cam kit myself.. it's pretty easy, actually ) and a haynes manual. The only assistance I needed was in guiding the engine into place with the hoist.
Regardless of how you do the swap, get an appropriate torque converter built. It's a pain to have to install one later, when it would have been so easy when the engine was out.
You might wanna try it yourself
Old Nov 9, 2003 | 02:37 PM
talos's Avatar
make sure if u do this ur self, that when u do the springs or anything, u get some compressed air in there so u don't drop and valves bad memorys
Old Nov 9, 2003 | 05:23 PM
StoveBolt's Avatar
take your time and do it yourself .. not hard at all .. its quality time and you will bond with the car
Old Nov 10, 2003 | 07:47 AM
jy211's Avatar
We charge $150-$250 to take the motors out......installation depends on what needs to be done.....
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
deadmanrunning
Jan 3, 2015 01:12 PM
