no spark
Old Oct 2, 2003 | 12:55 PM
xItsMike's Avatar
no spark
79 z28 - starter is turning engine normally, but it wont start. checked spark cables and im not gettin any spark on the spark plug end. So its gotta be a distributor problem right? i know the cables themselves are good. i got the ac delco - remy distributor, how do i find out what exactly it is and then to repair/replace.
Old Oct 2, 2003 | 02:46 PM
kacy's Avatar
look at the underside of the car to see if it worn out so it wont let spark jump for the coil plug to the rotor if these look new then its probably your ignition control module located under the rotor check these and let me know how they look
Old Oct 2, 2003 | 07:57 PM
xItsMike's Avatar
wait what am i looking for on at the underside of the car?
Old Oct 2, 2003 | 08:55 PM
angel71rs's Avatar
I think he meant cap, as in distributor cap. They can get carbon tracked so spark goes elsewhere instead of to spark wires.
You can take the module to Autozone and they will test it for free. Can also be the coil.
Old Oct 3, 2003 | 06:11 PM
xItsMike's Avatar
I took out the entire distributor, disassembled and cleaned out corrosion and whatnot, wires were good and i installed it back, rotor spins still no spark in the spark cables. how do i test the ignition coil.
Old Oct 4, 2003 | 11:13 AM
kacy's Avatar
sorry i did mean cap not sure if you can test a coil other than by replacing it with a good one but i bet this is your problem
Old Oct 4, 2003 | 02:25 PM
xItsMike's Avatar
thanks but i doubt that is my problem, i have a fairly new msd 6al ignition module.
Old Oct 6, 2003 | 10:29 PM
jons69's Avatar
12 volts
this same thing happened to me in my 69. I replaced everything inside the dist, and nothing worked. I eventually gave up, and hauled it to my mechanic. He looked at it for about half an hour, then fixed it. The power wire going to the dist, wasn't giving a full 12 volts. He replaced the wire and it started right up.jon
Old Oct 8, 2003 | 07:01 AM
grygst76's Avatar
Re: 12 volts
thats the problem chief!!
cut the red wire or power lead to the distributor and then reconnect it you'll be amazed..
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
