69 Camaro Emissions
Old Oct 1, 2003 | 07:09 PM
CamanZZ4's Avatar
Angry 69 Camaro Emissions
Guys, I have a 69 Z/28 with a ZZ3 350 running a 750 Holley. I rejetted down from 75-65 primarys and leaned it out to 1/2 a turn. I added NOS Octane additive with about 1/2 tank of gas. I passed everything with flying colors except the Idle Hydrocarbons. Reading was 505 max 450. My CO at idle was .7 max 5.0. Any quick fixes. AZ really needs to get their head out of their butt on collector cars!!
Thanks, Dennis
Old Oct 1, 2003 | 09:25 PM
Eric G's Avatar
getto rig as many cats as you can in the exaust?
put the iron manifolds back on?
cover over a hole on the carb and jet it even lower?
Old Oct 1, 2003 | 11:11 PM
Got-LT1's Avatar
High HCs are usually the result of a dirty engine or running rich. I failed the NJ test (much tougher than yours) due to an exhaust leak and a bad fuel injector. Look for exhaust leaks or check for a rich condition.
Old Oct 2, 2003 | 08:30 AM
DropTop91's Avatar
you have emission checks on a 69 camaro??? Thats retarded!!
Old Oct 2, 2003 | 08:36 AM
Jeff H's Avatar
You need to fool around with the timing and idle adjustment screw. I had a 68 Camaro SS396 that was built up big time and we were able to get it to pass NJ emissions. It was pretty much impossible to drive, but it would sit there and idle and pass emissions. After passing, I had to readjust the timing and carb all over again.
Old Oct 2, 2003 | 08:44 AM
Todd80Z28's Avatar
I'd say that people who run their cars so rich that there's a black cloud behind them need to get their heads out of their butts.
Seriously, though, put the thing on a sniffer, and figure out your idle and run A/F. Jet the primaries to stay close to stoich (14.7:1) and you'll be fine. You'll also likely be amazed at your improved gas mileage.
If you're already too lean (not what you think, but what the machine shows you- I find that nearly EVERYONE runs their carb too rich, particularly Holleys), pull the timing back about 5 degrees and run the test again. Over-advanced timing will increase HC as well. In fact, with low CO, I'm guessing that's what it might be.
Todd
CARiD
Jan 14, 2015 04:00 AM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
ChrisFrez
Dec 7, 2014 06:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
