Engine Combo?
Old Oct 24, 2003 | 03:38 PM
KC-71's Avatar
Engine Combo?
I'm saving up a bunch of money to put into the engine, and ive spent a lot of time thinking about what to put into it. I decided I want to get vortec heads with the Edelbrock air gap intake (vortec) and Comp Cams Magnum self aligning rocker arms 1.52 (I heard you can't go to 1.6 without problems, and either ross or speed-pro pistons (giving around 10.5:1 compression). Obviously, I'll have to put in a bigger cam (stock right now) and I just installed an MSD pro-billet w/blaster coil, and have a holley 600 4 barrell. (Transmission is TH-350). Will this set-up work together or will I run into problems? Thanks.
Old Oct 24, 2003 | 03:42 PM
talos's Avatar
looks good, but i don't know why u couldn't use the 1.6 rocker rollers.. the only things i would do different, i would take the block .30 over to take out any tampering that would be in there. for any intake i would go to a Victor Jr. and a little larger carb like a 750.
Old Oct 24, 2003 | 09:34 PM
sleepybu's Avatar
how fast do you want too go
heres a few combos...
http://www.ryanscarpage.50megs.com/combos1.html
Old Oct 25, 2003 | 05:30 PM
StoveBolt's Avatar
i'd just put a big block in it with a big cam ..
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
92ragtop
Dec 27, 2014 01:56 PM
Nostang 96z
Sep 15, 2002 10:15 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
