my chevelle engine plans
Old Nov 20, 2003 | 10:39 PM
96LT14u2Nv's Avatar
block:87 truck block(roller) bore .40 over
crank:scat nodular 9000
rods:Stock LT1 or scat/eagle i-beams
pistons:Speedpro powerforged (9-9.8:1 comp)
cam:218/224(.495/.503) 224/230(.503/.510) 222/230(.509/.522)
heads:Pro Topline 180cc (64cc,1.50/1.94) +3angle valve job/port work OR: stock vortech iron heads
intake:edelbrock performer or performer RPM
carb:Barry Grant road demon (625/725cfm) OR speed demon (650/750cfm)
exhaust:hedman 1 5/8 full length w/ dual cutouts and flowmaster catback
how does that setup sound?im aiming for at least 300HP to the wheels (350-400FWHP) this is going to just be a cruiser
which heads should i use? which cam looks best (dont want to have to get a big stall to get the car moving,needs to be STREETABLE)? will stock LT1 rods work? which of the carbs is the best? stick with 1.5 or go with 1.6 RR's?
OR: i was thinking about doing a 383. should i get the Pro Topline 200cfm heads with a 383? what is the most compression u should go with iron heads? is a 383 worth paying the balancing cost? i would use one of the cams above,5.7 rods,ect.
i will be running a TH350 with a stg.1 rebuild,2400 stall and 3.55/3.73 gear.
thanks for any suggestions
meissen
Jun 1, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
nballisru
Dec 14, 2014 05:01 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
