PDA
View Full Version : Forced Induction
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Any try E3 spark plugs?
  2. Newbie needs help lt1 383 f1 procharger
  3. Turbo 3rd gen
  4. Suggestions
  5. Huge power loss on the dyno . Need help
  6. Supercharger Belt for 7" crank pulley
  7. MAF recomendations
  8. 94 Trans Am Rough Idle - Forced Induction
  9. 94 Trans Am Rough Idle - Forced Induction
  10. Hydro carbons too high.
  11. New here. Need help.
  12. Metal Intake Elbow for forced induction
  13. Adding turbo to 1994 trans am
  14. Anyone twisted the nose off an LT1 crank using a centrifugal blower?
  15. F2 427SBC '69 Camaro
  16. 1995 z28 a4 supercharger
  17. Turbo or Supercharger?
  18. Car running lean under boost!!!
  19. Custom oval y pipe. Pros and Cons?
  20. S/C LT1 Data Logs for Review
  21. stock heads and supercharger
  22. How to ready 93 z28 for supercharger
  23. Need Cooling Help
  24. help tuning 383 procharged
  25. lots of blue smoke on newer engine? turbo
  26. Modifying advice
  27. 94 z28 le2 kit wanting to boost it ?!?!
  28. Injector sizing question
  29. BOV question
  30. After a year its almost done!
  31. D1SC air inlet options - LT1 need help/advice
  32. Is an adjustable FPR requied on boosted applications?
  33. pro charger question
  34. Turbo lt1
  35. HP Tuners for Boost....
  36. Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG
  37. CX RACING intercooler
  38. Turbo advice...
  39. Some blower piping upgrades
  40. Starting out on a 5.3 Turbo setup for my 96 Z28...
  41. Total Price
  42. cam
  43. 383 AFR 227 Heads and an F1a @11.5-12psi
  44. Stalling at a stop after warmed up ...
  45. 4L60E life with an S trim LT1, should I even try?
  46. wanting to boost in the future but building motor now
  47. Turbo or Supercharged LT1
  48. plug gap opinions waqnted
  49. Thinking about Putting a twin Turbo on this Camaro, PIC
  50. Sunday at Musclepalooza with the TurboZ28..
  51. Head/cam/intake and gaskets for high boost
  52. Any of you FI guys using the High Impendance 1000cc and above injectors?
  53. Need good tuner in SoCal for Vortech LT1
  54. T4 vs T6 on LQ4
  55. Going with twin GT35's ...
  56. LT1 turbo drain to oil pan...
  57. Keyed hub with stock cover?
  58. Any of you running an Aeromotive 340 lph fuel pump?
  59. 97 SS rear mount turbo???
  60. Help! Rear mount turbo exhaust issues. Changed diameter.
  61. Run LT1 built for boost with no boost :(
  62. Turbo Headers - Which Ones??
  63. need help
  64. Vortech T-Trim vs Y-Trim
  65. upgrade options for current p1sc? (doing a 383 build)
  66. crank hub adapter and harmonic balancer options???
  67. JGS Wastegate issues...
  68. difference of these two cams?? blower 383
  69. Air Filter size important on Turbo engine? Yes!
  70. The final rebuild.hoping for 650-700rwhp
  71. which heads: 62cc chamber/215 intake...or 58cc chamb/195 intake
  72. 14psi supercharger- Which heads 195, 200, 215 ?
  73. Pressure testing the cold side...
  74. Pics of my stock fans as pushers - LT1 Fbody 4th Gen Turbo car...
  75. Burnt T4 Shim gasket...
  76. Blower Cam ideas on 383 build -14psi boost
  77. 97 z28 turbo help
  78. need info
  79. procharger d1sc
  80. keep the stock engine oil cooler or get rid of it
  81. Ring Gap
  82. 2 bar MAP part numbers
  83. LT1 boost kit - Excellent!
  84. Procharger Case Ventillation (self-contained units)
  85. help! fuel cutting out high rpms..bigger fuel lines?
  86. Considering buying a 96 z with a powerdyne
  87. Saga continues...
  88. Idle problem
  89. yep...another pcv evac question...lol
  90. Single Walbro support 355 w/10 PSI (~535 RWHP)???
  91. Meth users: What is you timing curve??
  92. Does anyone still make TurboKits for this motor?
  93. Project: Boosting Rocky!
  94. Fun(?) on Saturday...
  95. need help troubleshooting??
  96. New Turbo and hotside installed. Issues and resolving them...
  97. Forced induction tuning question
  98. Finishing up new hotside install...
  99. 4turbo 5.3 in a 4th gen.
  100. Paxton sn93 sensor question.
  101. Welding aluminum tubing with Alumiweld...
  102. Ignition box necessary for Forced Induction?
  103. Critique my build
  104. FMIC for a 96Z28
  105. Rings - Gapless Top vs Gapless 2nd?
  106. Signs Of Supercharger Belt Slippage ??
  107. Worth changing cams for turbo setup?
  108. Made some good progress today in the new kit install...
  109. Reclocked PT76GTS, what torque spec for housings?
  110. Installing new kit. Turbine interfering with bypass pipe...
  111. Turbo Lt1's: whats the highest PSI you've attained?
  112. What power difference will I see between these two sets of heads with my combo?
  113. 355 has blow by.Time for a 383 build
  114. New Aeromotive 340lph fuel pump..
  115. Bolt on Power Steering setup for Turbos?
  116. Finally alive after 3 lonnnngggg years!
  117. Considering switching built 383 to FI. Advice?
  118. What will you be doing to your FI Camaro over the winter?
  119. OLD LT1 Paxton Blower Setup
  120. New Hotside ... :)
  121. 2-bar Map Sensor information-volts @ kpa
  122. front mount intercooler in 95 T/A anyone have it and can help me with parts list, pic
  123. 2 bar map question
  124. Turbo Upgrade :)
  125. Turbo LT1 Cam
  126. Winter build Need opinions on my path..
  127. supercharger or turbocharger? 96 z28
  128. Twin 76mm 383 LT1 build thread
  129. Need BOV advice/help...
  130. ATI Procharger people--anyone using a different oil?
  131. Any vendors here selling the JGS 40mm WG?
  132. Name this Turbo...Old STS kit?
  133. should i switch my ai blower cam???
  134. intake backfires?? caused by oil catch can?
  135. boosted lt1. a little disappointed on power....
  136. Will this chane tune!
  137. going boosted for the first time. piston and ring ideas?
  138. Throttle Body Pipe Fittings
  139. Idler Pulley - Locked
  140. LT1 Vortech oil drain question
  141. 3 Bar MAP question(LT1)
  142. HOw high do you guys spin your boosted motors
  143. fuel file help for fast classic
  144. Anyone have a 4L80E installed in your Turbo LT1 Fbody?
  145. LT4 knock module and boost - yea or nea?
  146. Another cam question...
  147. Have a dump pipe off the turbo?
  148. Signal hose came off Manual boost controller. 19psi!
  149. Any turbo guys with 4000 stall TH350 here?
  150. Procharger tensioner
  151. Got 3 passes in tonight before the rain stopped us...
  152. radiator and fan?
  153. boost gauge reading vacuum, no boost at wot.
  154. Going "Drifting" - Advice please
  155. CC503 or LE 228/236 on blower application
  156. Base tune for fast classic.
  157. boost controller
  158. Getting belt noise after going WOT
  159. what are the pros/cons of ditching the pcv system (93 lt1 boosted)
  160. Turbo Headers for a customer
  161. procharger crank pulley (any one makes besides procharger)
  162. 383 0rocharged idle surge.
  163. Top piston ring suggestions for boost/nitrous
  164. IAC on turbocharged LT1
  165. currently running Supercharger and Nitrous... meth too
  166. PCV/breather/oil seperator?
  167. How much vacuum?
  168. Is it ok to have a 3.5" to 3" reducer...
  169. Boost Gauge Installation
  170. What size is the oval opening for LT1 TB's?
  171. When is beaded intercooler pipe necessary?
  172. Same PSI, big blower or small blower makes better low end and mid range?
  173. New Build for the shop car
  174. ngk tr6 or autolite AR103...std copper core..which is the better for boost?
  175. Made a new Cobra owner unhappy...
  176. Manual vs Electronic Boost controllers...
  177. Whipple prototype for LT1's.. Have you seen this?
  178. Selling my longblock - 385cid w/AFR heads for boost
  179. Thinkin it's turbo time...cam question
  180. Where to buy FMIC and piping for procharger?
  181. here some pics of my new twin turbo hot pipes
  182. need some advice felpro or impala head gaskets ?
  183. budget turbo build Qs?
  184. Boosted 355 guys - What pistons?
  185. going lean with boost
  186. Fuel problems at boost
  187. dual power adders?
  188. Twins with Y pipe?
  189. Need boost advice for 383 with currenty 12:1 CR - which pistons
  190. Impeller speed vs boost?
  191. T-Trim Pulleys
  192. Bare minimum to run 8-10 lbs. boost safely noob questions..
  193. Has anyone here swapped their journaled cartridge for a Ball Bearing one?
  194. optimum CR for stock bottom end, p600b 10 psi boost, '93 w/ AFR 210 heads
  195. whats your favorite lt1 head gasket (FI) and why?
  196. Lt1 catch can recommendation
  197. PCV valve oil separators? any recommendations?
  198. Vortech YSI brackets ??? Who makes/sells them ???
  199. inside of my 93 lt1 after 5000 miles of supercharger
  200. T76 vs 88mm turbo (stupid) question...
  201. Supercharger pulley wobble, how to fix?
  202. Bolt-in vertical radiator? Without cutting frame?
  203. AFR 210cc on stock bottom end w/ p600b...will i be happy?
  204. what piston dish (cc) are you running on your boosted lt1 and whats your compression
  205. Idle issues.
  206. 112 lobe center smog legal?
  207. whats better? deep piston dish/shallow head cc or shallow dish/big head cc
  208. dyno dissapointment
  209. meizere electric water pump, yay or nay? w/ forced induction lt1?
  210. 200 shot on top of 15psi blower possible?
  211. Pros and cons of E85.
  212. What stall and rear gear ratio for turbo car?
  213. anyone using Autozone PCV1118 (Luber-finer) valve?
  214. methanol pump location?????
  215. question about Boost and PCV valves
  216. Shownomercyz28's Turbo Build... courtesy of LT1Boost
  217. Lloyd Elliot finished my TFS heads.
  218. Powerdyne LT1 install 2 questions
  219. question bout a charger
  220. Turbo Build For Jason Short
  221. Powerdyne on 94 LT1, need info, injector size, fuel pump etc...
  222. Wastegate vs Blowoff
  223. Best gear ratio for FI car
  224. hotcam vs. blowercam on supercharged ltx
  225. Simple Electric 12v waste gate/BOV
  226. BOV location
  227. Any interest in builder turbo kits?
  228. What do you know bout this companies product?
  229. Any F.I. guys using the Impala SS stainless shim head gasket?
  230. Those'who have done the EFI 24X coversion (that are boosted), I have questions...
  231. 50/50 methanol/water or ethanol(denatured alc)/water ?
  232. LT1 love in GM High Tech
  233. LT1 Bank 2 running Lean!! Please Help
  234. LT1 Boost Customer Roll Call!
  235. looking for conservative ls1 turbo set up??
  236. P600b Qustions and Dryer Hose
  237. Thinking of going vic jr intake. What all do I need to consider?
  238. Thinking of Selling the LT1 Boost Shop Car kit
  239. gmhightech puts waste gate on supercharger
  240. LT1 Boost PT88 Build
  241. If my Electronic boost controller is set to 15psi, should I hear it open at 5psi?
  242. Twin 76mm on a LT1?
  243. Powerdyne rebuild #2 ...what to do..what to do ....928 Motorsports?
  244. whats the better block for me to build up? 2 bolt or 4 bolt lt1?i
  245. sbc turbo manifolds
  246. Pro Charger for LT1 BD-11
  247. supercharged stock bottom end ltx dyno results
  248. Boosting an LS1
  249. ltx vs. lsx forced induction builds
  250. LT1 Boost Customer build... again
