Turbo LT1 Cam
Old Sep 10, 2012 | 07:50 PM
ShownomercyZ28's Avatar
Turbo LT1 Cam
I need a cam specced out for the new bullet.
Engine is a 383, static CR ~9.5, stock castings ported to flow 263/206, single plane with a elbow and 90mm TB. Will be a front mount pt76gts turbo, larger intercooler and meth.
Goal is max power round 6000-6200, shift round 6400 area. (MVB TH400)
A real popular cam spec for turbo builds seem to be these...
224/224 .573/.565 114 LSA
Or, step up to this size
224/236 114 +0 (.605/.593)
Or, a mix of the two, so like a 224/230, or a 230/230
Lobes will most likely be XFI, or XE if I have to, pretty sure springs/lifters can handle the ramp rates fine.
Old Sep 10, 2012 | 08:02 PM
BlackbirdWS6's Avatar
Re: Turbo LT1 Cam
I would go with the 224/236 since you plan on throwing on better heads in the future. The 224/224 will be too tame IMO and you don't want to go wild.
Old Sep 10, 2012 | 08:04 PM
Re: Turbo LT1 Cam
Comp Cams said 230/230
:shrugs:
Old Sep 12, 2012 | 07:51 AM
DirtyDaveW's Avatar
Re: Turbo LT1 Cam
I have a CC turbo specific cam that is much like your first one.
In a naturally aspirated/N20 incarnation, I had the 224/236, albeit with a 112 LSA.
For my daily driver/freeway assassin Turbo setup, the cam gives me the best of all worlds. Drives like a bone stock LT1 in Houston, Summer, bumper to bumper traffic, yet murders everything I've ran(GT500's, non-Liter Sportbikes, EVO's, Turbo Neons, Subaru WRX/STI, Cobras, Vettes, Fbodies). My freeway mileage from Albany to Rochester (contract work) is 20+ miles per gallon with the M6, 3.55 gears.
Old Dec 17, 2012 | 11:07 AM
engineermike's Avatar
Re: Turbo LT1 Cam
I had a 224/236-114 "SC" cam in my turbo LT1. I listened to all the hype about "turbo cams" and bought into it. I installed a 226/226-114 in the same motor and it turned into a slug. I wound up putting the 224/236 back in it and got all my power back. Sure am glad I didn't go reverse split...
Old Dec 18, 2012 | 08:00 AM
DirtyDaveW's Avatar
Re: Turbo LT1 Cam
Mike, do you still have that cam card around for your 224/236? I had a Nitrous Xtreme iteration of the CC224/236 and it had a sexy choppy idle. It (and a 100 shot) sent my otherwise N/A 355 cubed, 3.42 geared, 2800 stalled TH350, 3650lb car to a 11.1 @121mph using ET streets on salad shooters w/1.6 sixty foot. The lift on that was only .57x from what I remember and had a 112 lsa.
Old Dec 18, 2012 | 09:24 AM
Re: Turbo LT1 Cam
Mine was on a 114 using Xtreme high-lift lobes.
LeftoverChinese
Jan 14, 2024 03:03 PM
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
blac94Z
Jan 22, 2015 11:19 PM
