Anyone twisted the nose off an LT1 crank using a centrifugal blower?
Old Feb 17, 2016 | 12:49 PM
LT1inaMGB's Avatar
Old Feb 17, 2016 | 09:12 PM
parkers Z28's Avatar
Re: Anyone twisted the nose off an LT1 crank using a centrifugal blower?
Was it a stock crank ??
Old Feb 17, 2016 | 09:44 PM
LT1inaMGB's Avatar
Mine hasn't broken, I was just curious if anyone has heard of it happening. The pres of Scat says it is common
Old Feb 18, 2016 | 09:48 AM
How much boost? Stock crank or aftermarket? Buddy of mine had a 383 LT1, Callie's Stealth with standard SBC snout, was running 20# + of Vortech boost, making 1,125 HP at the flywheel. Only problem he ever had was the ATI damper hub cracking. Solution was double key the crank and put a reinforcing ring around the outside of the hub.
If you are concerned, you can get aftermarket cranks with a BBC snout.
Old Feb 18, 2016 | 01:14 PM
LT1inaMGB's Avatar
Probably won't have an issue then. Mine is a stock 350 LT1 crank with forged pistons and Scat 4340 rods. I run less than 10 psi with a Vortech and don't turn it past 6000 rpm. It makes right at 500 rwhp and 540 rwtq.
Old Apr 8, 2016 | 05:23 PM
Kevin Blown 95 TA's Avatar
It used to be an issue. That's why some guys were using big block snouts on SBC cranks. I believe it was some of the Eagles that broke the snout off.
95maroboi
Jun 7, 2015 12:18 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
