need help
Old Oct 9, 2013 | 07:59 PM
Paul Hlavaty's Avatar
Question need help
looking to turbocharge my 95 Pontiac TransAm. i have the Lt1 converted to Lt4 bored 60 over and stroked to 388ci. what must i do to the motor to turbocharge it and what size turbochargers should i use?
Old Oct 10, 2013 | 02:06 AM
97WS6SCharged's Avatar
Re: need help
Going to really depend on what pistons/heads you used and how much power you're looking to make.
Old Oct 10, 2013 | 06:49 PM
Re: need help
looking to reach around 800 chris. im rebuilding the whole motor. im looking for suggestions on parts. its mean now but i want MORE!!!!
Old Oct 10, 2013 | 10:10 PM
Re: need help
You'll obviously want to use some good quality parts at that level. JE, Callies, Oliver, ARP, that level of stuff. 9:1 with good heads and a all the supporting mods with a PT88 would be a good start. Jon at LT1 Boost can build the turbo kit if you don't have one yet.
I'd probably start with a fresher block personally. 60 over is going to run hot which isn't a good start for a FI build.
Old Oct 12, 2013 | 08:21 AM
Kevin Blown 95 TA's Avatar
Re: need help
Yeah, get a block with a stock bore and pay to have it sonic checked to ensure that you have good cylinder wall thickness and checked for cracks before before you do anything, then bore it 30 or less and go from there. It's not cheap what you're talking about doing, so you might want to sell grandma to the Huns for a little extra cash. 800 at the flywheel isn't hard for a turbo engine, but the rest of the stuff in your car will be inadequate - drive train, fuel system, ignition, suspension, maybe cooling system (brakes!).
Old Oct 12, 2013 | 08:02 PM
Re: need help
Alternatively you could shove a stock 5.3 or 6.0 LSx in it with a big turbo. lol
