Is it ok to have a 3.5" to 3" reducer...
Old Mar 25, 2012 | 06:22 PM
Mizz96Z28's Avatar
on the inlet side of the MAF sensor in a forced induction application? I want to go for a cleaner look in the engine bay so I want more polished pipe and less hose and I have plenty of 3" pipe left over from my IC rerouting. I was wondering if it would have a negative effect on airflow going from 3" to 3.5" right at the MAF or not.
Old Mar 30, 2012 | 07:56 PM
Jasonz28camaro's Avatar
Re: Is it ok to have a 3.5" to 3" reducer...
hopefully not, i just did it on mine lol.
Old Mar 30, 2012 | 08:33 PM
96capricemgr's Avatar
I would avoid diameter changes too close to the MAF. You could make the distribution of flow across the cross section uneven, like maybe a slow area around the perimeter. If you understand how the MAF works you will understand even flow through the entire cross section is important to accuracy.
On my NA setup I found a short cone filter with the inverted cone inside was enough to screwup MAF readings. I would think the more air you move the more important a clean approach to the MAF is.
