i need a slip yoke???
Old Dec 16, 2012 | 12:18 PM
mutlyi4's Avatar
i need a new slip yoke on my drive shaft my car is a 97 v8 with auto trans where can i find one i have had no luck so far dealer said its discontinued
Old Dec 16, 2012 | 05:48 PM
Kevin Blown 95 TA's Avatar
Re: i need a slip yoke???
Check locally for a driveshaft shop, places like Drivetrain Specialties & Drivetrian Specialists, junkyard,
Post in the parts wanted section - maybe someone has a OEM drive shaft they don't need - lots of people have upgraded the DS and have the old one laying aorund still.
Maybe you should also list your location in case someone locally can help you out.
Old Dec 16, 2012 | 06:03 PM
Might want to just get the aluminum DS from a 98-02 LS1 or a 1LE.
I have my stock DS and it was pulled out of the car with only 70,000 miles on it, 12 years ago. Separating the u-joint is the big issue. If you are nearby, you can have it free.
What happened to yours? Bad u-joint, twisted splines, fractured yoke?
Old Dec 17, 2012 | 08:01 AM
mutlyi4's Avatar
im in central fl
and the bushing in the tail shaft of the trans went bad (to much clearance) and it wore a grove about 2inces wide and about 1/8 inch deep in the yoke
Old Dec 25, 2012 | 10:02 PM
scottshwtm's Avatar
Google N3R-3-6081X. That should be the correct one.
IndyZman
Oct 22, 2015 02:17 PM
ZXXVIII
Sep 1, 2015 10:13 PM
realistyc
Jul 28, 2015 07:32 PM
Jul 17, 2015 02:47 PM
4586
Parts Wanted
May 20, 2015 10:48 PM
