7-5/8" Rear Interchange Questions
Old Dec 8, 2012 | 04:37 PM
350350's Avatar
Got a few questions for those poe foke among us who are forced to live with our 10-bolts until Santa gets here...
1) Are all 3rd and 4th gen F-bodies the 7-5/8" ring gear? Did they ever have the 7.5"?
2) Do all 7-5/8" rears have the same axle splines? For example, if I get a 99 S10 center section will the spiders have the same splines as an 89 Camaro axle?
3) When did they stop making the 7-5/8"? Did they ever stop? Please tell me they stopped that. What do new Trailblazers use? I have to think an LS-engined Trailblazer SS would eat one a day?
Just trying to figure out what all GM models of vehicles to scavenge for parts.
Old Dec 9, 2012 | 08:06 AM
FirstYrLS1Z's Avatar
Re: 7-5/8" Rear Interchange Questions
the 7.5/7.625 designations ONLY apply to the gearset.
7.5 is the same as 7.625.
a 7.625 rearend has a 7.625 OD ring gear mounted on a 7.5 carrier.
a 7.5 rearend has a 7.5 OD ring gear mounted on a 7.5 carrier.
rearend parts are the same: bearings,seals,shims,etc.
they might have gone to the 7.625 gear in 1994,not sure.
older splines were 26,think that ended in 1988,not sure.
Go to some rearend sites,like Richmond,Motive-lot of interchange info.
Old Dec 11, 2012 | 08:36 PM
350350's Avatar
Thanks man I didn't think about going to a gear site to look for interchange, will report back if I find anything useful!
Old Dec 12, 2012 | 09:40 AM
87DJP2001's Avatar
10-bolt 7 5/8 & 7.625 ( faction & disimal) sre the same dia for gear size.
Old Dec 12, 2012 | 04:14 PM
350350's Avatar
Looks like generally speaking 1978-2002 pretty much is universal for 7.5 and 7.625" components.
However, I do see some hints that the 2002 Trailblazer may have had a different unit, so I'd only rely on up to 2001 to be sure.
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 13, 2015 09:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
FiNSTa
Jul 20, 2002 10:57 PM
