4L60E Transmision Problem 3 and 4th
Re: 4L60E Transmision Problem 3 and 4th
The 3-4 clutches are a common problem in stock 4L60Es. GM had several "design flaws" that contributed to it. We make numerous modifications and changed to them to eliminate the causes.
Frank
Frank
Unfortunately not. Fixing all the flaws is a pretty in depth procedure. It is possible to just replace the 3-4 clutches, but this still requires removing and diassembling the transmission. Even if you just replace the clutches, the problems that led into it will still be there, and it will continue to happen.
Frank
Frank
