ring and pinion
Old Aug 27, 2013 | 10:38 PM
IndianScout's Avatar
ring and pinion
my car came with the GU2 G80, I want to swap out the gears to 3:23's when I change out the ring and pinion if I lay the spacers out in the order I removed them. Do I still need to have the rear end setup or should I take it to a shop and have them do the swap for me?
Old Aug 28, 2013 | 05:56 AM
FirstYrLS1Z's Avatar
Re: ring and pinion
GU2 gears(2.73) came on a 2 series carrier. 3.23 gears will not work with a 2 series carrier,you would need a 3 series carrier. The only gears that'll work with a 2 series carrier are 2.73(GU2),3.08, and aftermarket 'thick' gears of 3.42,3.73, & 4.10.
Whenever a gearset is changed,pinion depth and set 'lash' has to be set. Any shims/spacers(pinion & carrier) from the current gearset are only a starting point in 'setting up' the new set.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
