no drive gears only reverse??
Old Jan 24, 2014 | 03:46 AM
CHIEFs89427's Avatar
I've got a 94 z28 with a 4l60e and I just rebuilt the engine. After I got it running it wouldn't go into reverse. It would go threw all 4 gears in drive but no reverse. Then one day I said the hell with it imma drive it annyway so me and my cousin took turns drivin it up and down the street. Before I parked it, it was grinding alil. Later that day I started it and it grinded alil more then the reverse worked. Now the drive is not engaging it acts like its in neutral when I put it in any of the 4 gear positions. Any help would be appreciated. Maybe the torque converter but don't wanna buy one and it still do the same thing???
Old Jan 24, 2014 | 09:01 AM
12SCNDZ's Avatar
Re: no drive gears only reverse??
If you hear it grinding, you most likely have rear planetary damage.
Frank
Old Jan 26, 2014 | 02:13 PM
Well its not grinding any more it just acts like its in neutral. When I try to put it in any forward drive gear. And would I need a tranny rebuild to fix that, what you sayed it was?? Thanks for the reply also...
Old Jan 26, 2014 | 02:59 PM
LT4orbust's Avatar
yup, pull the trans, it'll be obvious
Old Jan 27, 2014 | 10:14 AM
12SCNDZ's Avatar
Once it tears all the teeth off the sun gear it will stop making noise. Yes, it's time for a rebuild. My guess is that if you drop the pan, it will be full of metal.
Frank
Old Jan 27, 2014 | 11:19 AM
Alright I'm guna take the pan off today ill let u guys know wut I see.
Old Jan 27, 2014 | 06:26 PM
I pulled the pan and filter off earlier, there was no O ring on the filter neck. I found a big black rubber gromet laying in the pan, it looks new like someone left it in there before? There was a little sludge stuck on the magnet on the pan. Could that metal sludge just be from normal wear? Because if I grinded a gear I would think there should be chunks in the pan not dust..
Old Jan 27, 2014 | 07:10 PM
12SCNDZ's Avatar
The 4L60E uses a metal clad seal that presses into the pump. It doesn't use an o-ring. If you don't see any large metal chunks, you most likely don't have a bad planetary. With that in mind, there are several other reasons for not having forward. The early 4L60Es had aluminum forward pistons that were notorious for cracking. When they crack, the fluid leaks through the crack instead of applying the piston. No piston apply means no forward clutch apply. No forward clutch apply means no forward. The other possibility is forward clutch failure. Try pulling the shifter into the manual 2nd position. If it moves forward in manual 1st or 2nd, but not manual 3rd or O/D then it's your forward sprag. If the reverse input oir low/reverse clutch is burnt to the point that it's locked on, you won't have forward either.
Frank
Old Jan 28, 2014 | 06:49 PM
Mr99SS's Avatar
I broke a sprag and did the same thing . Had to back it on a trailer
Old Jan 29, 2014 | 09:29 AM
12SCNDZ's Avatar
If it was a sprag, it would still move forard if you pulled it down to the D2 position... Unless there was also a problem with the over run clutches.
Frank
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Elcojoe
Nov 17, 2014 10:27 PM
