96 axle into 94
Old Oct 12, 2013 | 12:47 PM
Danok72's Avatar
96 axle into 94
I have a 94 a4 car (3.23) and have opportunity to buy a 96 m6 rear (3.42) is this a direct swap ? or what will need to be changed other than having the computer reset for the speedo. My 94 does not have traction control or abs and I dont know how the 96 rear is set up with a manual trans.
Old Oct 12, 2013 | 03:24 PM
rngilliland's Avatar
Re: 96 axle into 94
The axles are a direct swap. Since you don't have abs it doesn't matter if the 96 is traction control or not. If it is traction control you may have to use the brake hard lines from your 94 axle. If you ever want your abs to work you need a non traction control rear. I swapped a 3.42 axle into my 2.73 car and had to change the transmission shift points in addition to correcting the speedometer. I don't think changing the shift points would be necessary with such a small change in ratios.
Even though you didn't ask, unless something is wrong with your 94 axle or you're getting the 96 axle very cheap, I don't think the slight change in ratios is worth it.
Old Oct 13, 2013 | 10:11 AM
Danok72's Avatar
Re: 96 axle into 94
The 3.23 I currently have is making some unusual noises while turning that seem to be tied to wheel speed, I have checked the u-joints and raised the rear axle off the ground and spun it and no noise. I am getting the whole setup for $150 so I figured it would be worth it and possibly fix my problem at the same time.
Old Oct 14, 2013 | 11:26 PM
Re: 96 axle into 94
Sometimes noises when turning just mean you need some GM limited slip additive.
Old Oct 15, 2013 | 08:29 AM
Danok72's Avatar
Re: 96 axle into 94
I put in Lucas synthetic 85/140. It still makes noise and seems to be getting worse.
Old Oct 15, 2013 | 08:58 AM
Re: 96 axle into 94
Factory recommendation is GL5 80W90 with 4oz . of GM limited slip additive.
Old Oct 16, 2013 | 01:58 PM
Re: 96 axle into 94
You didn't add any LSA.
Old Oct 16, 2013 | 06:34 PM
Danok72's Avatar
Re: 96 axle into 94
I realize that the manual calls for 80-90 with L.S.A. I went with the heavier Lucas fluid to see if the noise went away, Lucas claims no L.S.A. is required with their fluids.
Old Oct 17, 2013 | 11:01 PM
Re: 96 axle into 94
Yeah and other brands say their LSA works just as well as the GM stuff, when it doesn't. The posi can make some really terrible sounding noises when it does not have the right stuff in there.
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
