how much total?
Old Jul 18, 2003 | 05:44 AM
94z28blue's Avatar
how much total?
i have very few mods but i want that big hp gain (doesnt everyone). how much in total, parts, labor, etc. did it cost do do a nitrous kit for about a 100 hp shot. whats the best kit for your money, and will this make me have to work on my car more than i drive it.
Old Jul 18, 2003 | 07:05 AM
TheZ's Avatar
i say around 1300.00 that covers all the goodies. But NX is commoing out with a direct port kit So, I would recommend that you wait a few weeks lol or months. BTW this didnt include the fuel pump you don't really need it you gonna spray 100 shot but anything over i highly recommand it
Old Jul 19, 2003 | 05:02 AM
94z28blue's Avatar
cool, im not gonna buy anything right away, just shopping to see how much im gonna be in the hole.
Old Jul 19, 2003 | 01:32 PM
Wild1's Avatar
If you go with the direct port route, plan on the price above plus a fuel pump and any progressive... $1700 - $1900. Half that of a supercharger without the tuning issues.
Old Jul 19, 2003 | 03:03 PM
rskrause's Avatar
Moderator
There are lots of people running 100-150hp nitorus shots without going the direct port route. My two nozzle 150hp system runs fine. The extra cost and complexity of direct port will be of most interest to people using 250+hp nitous shots. For this, you need a whole new motor as well!
Rich Krause
Old Jul 19, 2003 | 07:12 PM
Wild1's Avatar
True about the direct ports... but I was refering to the Noszle and NX NXL rail type direct ports without the drilling into the manifold. Seems to be fairly simple to install. I'm tending to go for the wet TB mount by Nitrous Works $600. I'm a bit concerned about the wet NX MAF and spraying around a 90* elbow. But I haven't heard of any problems with that kit.
Old Jul 19, 2003 | 09:58 PM
The NOSzles are $81 each..... almost $650 for a set of 8. The NOS NOSzle kits are $1,500.
Old Jul 21, 2003 | 09:28 PM
allnet777's Avatar
The NX kit is like 550. What else do you need besides the kit? Can you spray with just a kit. Doesn't a kit have everything, hence "kit"?
Old Jul 22, 2003 | 03:23 AM
Wild1's Avatar
Sure, but if it is a dry system tack on injectors and a pump. If it is a wet kit, you'll need a window switch. It really depends on what he wants. There are so many companies and so many different kits that some are complete and others are lacking. Defining "best" kit has different meanings. But you could get an entry kit for about $550.
Old Jul 22, 2003 | 08:55 PM
MARSTAUT's Avatar
alot of people use the NX kit which is what I use and you can spray with just the kit I also recomend the window swicth for safety and later on you can add the the bottle heater, purge (which is cool), fuel pressure guage ($215--recommended). and if you want to go with a 150 shot your going to need some ignition upgrades with a timeing retard ( around $400) . the system I have now is around 1300, kit, install, purge, heater, window switch, and fuel press. guage (not installed). but you can start with the basic kit and then add the goodies later. thats the good thing about N2o. if you go cam or SC you have to fit the bill at one time.
Old Jul 22, 2003 | 11:32 PM
Wild1's Avatar
Good point. You can build/customize piece by piece... but you'll get it running with a kit.
magman
Apr 15, 2016 03:08 AM
Henson071
Dec 30, 2015 09:55 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
