bottle heater questions.....
Old Jul 4, 2003 | 07:46 PM
TMDZ28's Avatar
in my bottle heater, there are two wires coming out. which of these two wires that i have to connect to the thermostat and to the power??? anyone can help me out here??? thanks
Old Jul 5, 2003 | 12:16 AM
sniffin94's Avatar
it doesn't matter which wire you run to the power. The other needs to ground
Old Jul 5, 2003 | 05:49 AM
sideways_Into_3rd's Avatar
neither one goes to thermostat .. u need to run a relay with ur heater .. the relay signal wire goes thru the thermostat
Old Jul 5, 2003 | 11:03 AM
TMDZ28's Avatar
what relay?? i dont have any relay, i only have two wire. that's it.
Old Jul 5, 2003 | 12:39 PM
Wild1's Avatar
Does anyone have a wiring diagram? Perhaps this will better explain it. A pic is worth a thousand words... one of Pamela Anderson is worth millions...
Old Jul 5, 2003 | 08:39 PM
robss96dcm's Avatar
did you look here
http://www.nitrousexpress.com/instal...terinstall.pdf
Old Jul 6, 2003 | 12:00 AM
Wild1's Avatar
Works for me...
Old Jul 6, 2003 | 10:55 AM
TMDZ28's Avatar
Originally posted by robss96dcm
did you look here
thanks rob, thanks wild1
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
weedog
Aug 15, 2015 08:23 PM
