n2o nozzle and injector question
Old Aug 12, 2003 | 01:12 PM
reuter's Avatar
hey i got a nitrous works wet kit but switched to a nozzle instead of the tb plate. does it matter which side is used for fuel and which side is used for the gas? i bought it used so i dont have instructions or anything. they both look the same size. also i mounted it in the IAT sensor's hole. what do i do with the IAT now?
another question, i got some NGK TR6s, theyre gapped to around 40 right now. what gap should i use? what can i use to compress them?
Old Aug 12, 2003 | 10:13 PM
elista's Avatar
add a little bit of wire (about 1 1/2') to your iat sensor and mount it closer to your air filter, it is a free mod.and it works. companys sell plug in kits but you can cut and splice if you want. i did it and have no regrets. seal it up with silicone but be careful not to get it in the sensor
Old Aug 12, 2003 | 10:14 PM
Wild1's Avatar
Yes, it does matter which side is used for fuel and which is used for N2O. There should be some marking for you... contact NX to get the correct set up.
You can relocate the IAT with a relocation harness. It will put if further towards the opening of the CAI.
Plugs should be gapped at .035...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
nophix
Nov 30, 2014 10:26 PM
