WOT switch question.
Old Jul 26, 2003 | 01:14 PM
SNEAKY NEIL's Avatar
I did a search and did not find what I needed. I bought the Jimmy Jams WOT switch and it has 3 prongs for wiring(2 side and one on the bottom) but the instructions for the kit show only 2 prongs. So my question is, how do I wire this from the NX switch panel to the WOT switch?
I am really bad at this wiring thing and I have had this kit for months just sitting around because I am not sure about the wiring. Thanks.
Old Jul 26, 2003 | 06:22 PM
LPEdave's Avatar
You probably only need two wires to the WOT switch. You just need to figure out which of those close a circuit when the switch is hit, and then get that switch into the circuit that powers the solenoid (along with your master switch, your FPSS, etc).
Dave
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
