compucar ?
Old Aug 6, 2003 | 01:10 PM
blackz151's Avatar
compucar ?
i have a computcar setup that came with my car. And the injector plate it came with isnt in the best shape. Where can i get a new plate?
Old Aug 7, 2003 | 02:40 PM
Timberwolf's Avatar
What's wrong with it? You can get a complete new plate right from compucar for $125 or so.
I have some spray bars and fittings if that's where your problem lies. I think you could have a whole new plate made at a machine shop for less than half what compucar wants for a replacement, and then all you'd have to do is switch your spray bars over
Old Aug 7, 2003 | 04:27 PM
Josh-'04 GTO's Avatar
You can do what I did and skip the plate idea all together. I didn't like the compucar set up so I used a NOS Fogger 2 nozzle instead. Lets you use standard flare jets instead of compucars threaded ones too.
Old Aug 7, 2003 | 04:57 PM
Timberwolf's Avatar
mine uses flare jets...
Old Aug 7, 2003 | 05:49 PM
That's weird, mine came with these funky threaded jets that I believe only Compucar sells. Much happier with the Fogger 2 nozzle. It appears NOS put a little more thought into their nozzles than Compucar did.
steelheart
Sep 8, 2004 05:40 PM
steelheart
Sep 6, 2004 07:59 PM
NinetySevenTA
Jan 6, 2004 10:16 PM
