how much timing retard for 300 shot
people have to ask questions to learn. Why get down on someone because they want to further their knowledge on something??? I personaly can't help you with the amount of timming you need to pull i just thought the last comment was rather rude.
Are you using a fogger or plate?
I would take out at least 15 degrees for the first hit. I also would put the car on fuel the first time as well. Look for specalling on the ceramic of the plug. If there is remove more timing or down jet the system. Also make sure you set up the fuel 100%. You need a real good tune to make real power and keep the pistons in it. Talk to you local NOS guru. Good luck.
thanks guys. i think i will have kenndys dyno tune in niagra falls ny do it when they install lt1 edit. but this helped me understand nitrous better. how long if tuned right till next rebuild? i used to run alcohol and we tore it down every year needed to. so how long i hope to get atleast 100,000 street miles i dont have funds like i used to
99TransAmWS6
Feb 3, 2015 08:27 AM
Lt1son
Dec 31, 2014 01:35 PM
