New Nitrous best,more to come.
Old Jul 6, 2003 | 12:02 AM
RacinLT1's Avatar
Went to cecil today,pulled about 50 more lbs outta the car,and ran the 175 jets.
First pass,in the heat but low humidity was a 11.02@124,7.06@98,1.62 60'
Not bad for a STOCK longblock LT1 and a 175 hit in 95° temps.
Later in the night i went a 11.09@122 with about 85-90% humidity,and another 11.02@122 at the end of the night. I couldnt bring myself to run the 200 shot just yet,cooler weather and the car will go 10's as is
Old Jul 6, 2003 | 02:55 PM
JSK333's Avatar
Awesome!
What fuel pump? And have you ever scanned a run to see if you're getting any knock?
I'm looking to do the same thing, but I'm still getting knock even with stock timing. I'm going to try new plugs and/or wires soon.
Old Jul 6, 2003 | 03:06 PM
RacinLT1's Avatar
walbro 255 in tank. I have a LOT of false knock from the exhuast hitting the floor,so my knock sensor is locked down to pull 2° max.
I read plugs more then i rely on a knock sensor,you get a better idea of what is really happening.
I also pull 3° through my MSD,and run VP C10 unleaded.
Old Jul 6, 2003 | 03:33 PM
TMDZ28's Avatar
you have a stock internal?? how many miles in your car?? that's some amazing times. do you have all the safety stuff??? i'm installing walbro 255 this month...
Old Jul 6, 2003 | 04:19 PM
RacinLT1's Avatar
yes completely stock internals,including cam/heads/tbody/etc. It does have 1.6 rockers.
63K miles. Safety stuff? other then guages,reading plugs,and good fuel and the pump,i have nothing else. Never liked using it,havent had anything but problems with FPSS's (thats just me).
Old Jul 6, 2003 | 04:20 PM
GJE94Z28's Avatar
Where did you get your Walbro in tank fuel pump, and how much did you pay for it?
Old Jul 6, 2003 | 04:33 PM
RacinLT1's Avatar
i got it 2 years ago from an old vendor from here (honestly dont remember thier name,but they were booted from the board for bad business deals). paid something like $109-119
Old Jul 6, 2003 | 04:42 PM
GJE94Z28's Avatar
Guess I better up grade the pump before I try the 150 shot. Was it a pain in the a$$ to install?
Old Jul 6, 2003 | 04:50 PM
RacinLT1's Avatar
not really,we just cut a hole in the floor and changed it that way. also had to modify/lose the fuel bucket.
There is a thread in LT1 tech about cutting the access hole,do a search and it'll come up.
Old Jul 6, 2003 | 04:59 PM
TCAL95Z's Avatar
those times are amazing.
How long have you been spraying on the stock bottom end?
Do you have any idea what your AF ratio is? When do you hit the nitrous?
Old Jul 6, 2003 | 05:11 PM
JWINN's Avatar
VERY IMPRESSIVE!
Now here is a guy that optimized the potential of a nitrous kit!
Stock engine and what not and the car is nocking on running in the 10's. WOW!
Those of you out there running stock engines with nitrous should be begging RacingLT1 for his tuneup/setup.
How many of you guy's can say you made your stock LT1 that normally runs either 14's to high 13's drop down to run low 11's? I would guess not to many of ya.
Great Job!
Jim
Old Jul 6, 2003 | 05:20 PM
RacinLT1's Avatar
never checked air fuel,dont have a wideband,and stockers arent worth crap.
Been spraying it for just under 2 years now.
I used to use a progressive to get if off the line,it doesnt seem to like that anymore. I have beter luck using a 2/10's of a second delay (that's 2/10's after WOT) and hitting it with all 175.
Jwinn,the car normally runs 12.5's or so in the heat,but im still amazed it's going as fast as it is.
Old Jul 6, 2003 | 05:48 PM
TCAL95Z's Avatar
Do you know what your car weighs?
What have you done to reduce weight?
Old Jul 6, 2003 | 06:25 PM
RacinLT1's Avatar
last time i wieghed it was 3590 with me in it. Since then i have pulled the bumper supports,which are around 50lbs.
Car has no ac/ps,lightweight carpet,chrome moly rollbar,Summit race buckets. The links in my sig have most of the info,but arent updated yet.
Old Jul 6, 2003 | 08:26 PM
GJE94Z28's Avatar
RacinLT1, do you have an AFPR? and if you do, what do you have it set at? thanks, Greg
