stock intake elbow, or tri flow??
Actually, the rubber elbow is probably better. You'll need to secure the nozzle in the elbow with a proper mount in either case. Some metal elbows have a "divider" down the middle which can affect N2O distribution on a Wet System. Plus, I've done a thermo check on the surface temps of rubber and metal elbows... the metal has greater heat soak absorbing the underhood temps.
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
