damn this bottle leak
my bloody bottle is leaking
. the thing is, it only leaks when i open it
. i put some thread tape in every joint. any suggestion to prevent this?? thanks
PS: my purge button is working again, by God it is so cool. i have not tried to use it yet. the traffic is too crowded right now
. i put some thread tape in every joint. any suggestion to prevent this?? thanksPS: my purge button is working again, by God it is so cool. i have not tried to use it yet. the traffic is too crowded right now
Re: damn this bottle leak
yeah, when u open the bottle it will leak if u have a loose connection. Open the bottle, listen around, put your finger on all the connections to see if u can feel it. When u find the leak, tighten it up
Re: Re: damn this bottle leak
Re: Re: Re: damn this bottle leak
i'll try that today, thanks man. is it gonna affect the performance of the nitrous though?? the pressure was 900 PSI, is it good??
Originally posted by 94DROPTOPZ28
If its leaking by the bottle nut maybe try putting 2 washers in there and when you do I know it sounds funny but lick your fingers and rub it on the washers before you put them in and it works
Originally posted by MydnightMyst
I just had that problem and I did this. I found the connection from the car line to the bottle was the issue. Not exactly the line itself, but the part that is on the bottle. The line wasn't seating properly to the bottle because I had disconnected and connected it so many times (and so clumsily), it had ruined the seating, therefore causing a leak. I fixed this problem by replacing the connector that seats to the line from the car.. If that makes any sense. Anyway, open the bottle wide. Another thing you can do is if it's cool enough, the nitrous should turn the area white (just in case you can't feel it). I went through every threading and taped them as well, but it took a plumber friend to figure out what was wrong. Luckily he was there!
I agree, but when you're hot after a leak, ya gotta do what ya gotta do.. hehehe..
I opened the bottle all the way for only a few seconds. Long enough to either pinpoint where the sound was coming from or to see where it was coming from..
I tried everything to fix it myself, but, like I said, it was my plumber friend who found the exact place and fixed it. Bless his heart!
Originally posted by Wild1
I'd recommend soapy water either spray or pour on... You'll see bubbles at the leak... good luck.
WobblySausage
Oct 7, 2015 02:44 PM
