safest way to do nitrous
Old Jul 5, 2003 | 03:30 PM
zuluman13's Avatar
I want to get nitrous whats everything i need to do it as safe as possible? And i need to do a complete stealth installation in the spare tire well and i need to hide everything. I also want to use a jacobs mastermin progressive controller for traction and it also has the timing retard so its only when i use it. The price isnt really a factor as long as i dont f*** up my car.
Old Jul 5, 2003 | 08:45 PM
zuluman13's Avatar
I also want a purge kit after just reading its helpful after you are done using nitous would i be able to make it spray under the car so no one sees it or would it not be useful there
Old Jul 7, 2003 | 03:32 PM
zuluman13's Avatar
ttt and would this be everytjing i need except a bottle opener is it worth using a progressive controller? Please help
http://www.lt1f-body.racenet.net/packages.php
Old Jul 7, 2003 | 03:40 PM
Hawk's Avatar
yes, thats a good kit to get with the safeties. you don't need a progressive controller yet, get the juice first and play around with it. If you feel you need it then order it. You can run a 100 shot on stock timing, just use 93 octane.
Don't order that kit from racenet if u can help it though, it will take you around 3 months to get it, trust me i know............
Try tbyrne, thunderracing, they are very good........
Old Jul 7, 2003 | 04:24 PM
TMDZ28's Avatar
can you use 91 octane?? that's the highest we have here in cali
Old Jul 7, 2003 | 04:35 PM
Hawk's Avatar
try it, get a scanner and see if you detonate. If so pull some timing.....................
Old Jul 7, 2003 | 07:12 PM
zuluman13's Avatar
if i got an aftermarket ignition can i make it retard the timing only when i use nitrous i think msd has something like that i use 93 but i would like to run a 125 or 150 shot i also want to upgrade my fuel system too any sugestions?
Old Jul 7, 2003 | 09:03 PM
Hawk's Avatar
get a fuel pump, pull 2 degrees, then monitor knock reatrd...........
Old Jul 7, 2003 | 09:05 PM
zuluman13's Avatar
but i dont want to lose na performance thats why
Old Jul 7, 2003 | 09:07 PM
Hawk's Avatar
Old Jul 8, 2003 | 02:53 PM
rpm4lalo's Avatar
Been there also, I try to deal with Thunder and Summit mostly.
Old Jul 8, 2003 | 09:43 PM
Red96Lt1's Avatar
Octane boost might help.
Old Jul 8, 2003 | 09:55 PM
zuluman13's Avatar
niether of those places cary nx and what would be a list of all the parts i need i so far think i need
the nx kit
jacob mastermid(decided it was the easiest way to do it so i dont need a window switch and it wont mess with my timing off nitrous plus i wont lose traction)
blow down tube
fuel pressure safety switch
bottle opener
bottle heater
purge kit
tr6 sparkplugs
nitrous filter
nitrous pressure guage
is there anything else that i would need or be useful
Old Jul 9, 2003 | 05:41 AM
94DROPTOPZ28's Avatar
As for the timing retard you are looking for you can go with an MSD digital 6 box which only retards the timing when the Nitrous is activated, and for your fuel set-up I would put in a Walbro 255lph in-tank fuel pump and you should have no problems spraying a 150 shot
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
