the nitrous works whoas
Old Jul 5, 2003 | 04:24 AM
moostadon's Avatar
Angry the nitrous works whoas
i just installed the nitrous works wet system and i have some poping when it is activated and some surging.the car feels like it falls on its face then it will go .i just checked the a.f.r. and it read
11:7:1 when its juicin .i was told i have to regap my plugs to about .035 from the stock .060 i also removed the hypertech engine tuning before i ran it .every time i check the bottle it has 900 pounds. i am flustered please help
Old Jul 5, 2003 | 09:46 PM
RUFFIDLNZ's Avatar
Did you regap your plugs? Also did you check the system before you ran it? If you didnt unhook the lines and have someone, or yourself hold the lines in a coffee can or something and then have someone operate the system and make sure you are getting both the juice and the fuel. Also are you sure you are running the right jets and what size shot are you running?
Old Jul 6, 2003 | 03:39 AM
moostadon's Avatar
well i just regaped the plugs to .035 and turned up the fuel pressure 44 psi i found it at 36psi before. ran great but bottle only had 600 psi.but i just remembered that i forgot to put the vacvuum line back on my regulator opps!!
Old Jul 6, 2003 | 11:05 AM
TMDZ28's Avatar
where's the vacum line man?? i want to double check that one also...thanks
MadMav
May 25, 2015 09:35 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
