$40...wasted
Old Jul 12, 2003 | 05:25 PM
Timberwolf's Avatar
$40...wasted
was finishing up my install today, so I got my bottle filled this morning while the shop was open. Cam home and commenced to work on wiring. Took me most of the day.
Around 3 pm, while I was in the car crimping and such, I heard a pop and see a white cloud as my tank proceeds to empty itself. The tank was sitting by itself out next to the car. The burst disk was brand new today! I had the guy at the shop install the safety fitting and new burst disk so I could install a blow down tube.
The tank is silver so it should reflect enough light so as not to get hot, and besides, today was partly cloudy and low to mid 70s. The tank shouldn't have over pressurized IMO.
If it can do that in the normal 70 degree heat, then what keeps it from popping when in my car all day in the sun under the hatch glass?
Should I talk to the guy at the shop and see if he wants to take some responsibility? Or is this normal?
Old Jul 12, 2003 | 05:49 PM
Wild1's Avatar
No, that isn't normal. Yesterday it was 118*F in Arizona and 110*F in Vegas... none of my buddies N2Os blew. Improper disk installation would be my point... I'd take it back to the guy immediately so he can't say you "tampered" with it.
Old Jul 12, 2003 | 06:29 PM
RacinLT1's Avatar
i would have to say it was a faulty disk. I have had bottle pressure upwards of 1300 and it hasnt popped. although i try not to leave it in the car baking all day if i can avoid it.
Old Jul 12, 2003 | 08:28 PM
funina91ss's Avatar
by chance was it overfilled?If not I would say bad disk like everone else plus how old is the bottle?
Old Jul 12, 2003 | 09:29 PM
OneFlyn95z28's Avatar
I would say he over filled it or installed the disk wrong
I have been juicng since the 80s and never lost a disk...even on over filled bottles in 110* heat in Texas
Old Jul 12, 2003 | 11:22 PM
Timberwolf's Avatar
The bottle was dated June '01 and was only filled to 9lbs...
Old Jul 12, 2003 | 11:53 PM
cavman12333's Avatar
yep and i have no a/c in my car
Old Jul 13, 2003 | 12:05 AM
Sparkz28's Avatar
damn..that sucks....it had to be the disc...take it back ASAP!
Old Jul 13, 2003 | 09:07 AM
Grover's Avatar
Who filled it Mike?
Old Jul 13, 2003 | 09:21 AM
Timberwolf's Avatar
Originally posted by Grover
Who filled it Mike?
Boost Unlimited
He installed the safety fitting and disk too. And of course they were headed out the door once they finished with me, so I can't go back til monday evening
Old Jul 13, 2003 | 09:42 AM
AutoRoc's Avatar
dhbf
That's ****ty! But I'd like to see that happen to an unrestrained bottle. Mine with like 400psi will fall over and spin if I sit it on the ground and open the valve
Take care of it quick! I wanna see some spray timeslips
Old Jul 13, 2003 | 09:46 AM
Timberwolf's Avatar
Re: dhbf
It was unrestrained, but it had that safety valve in it whish diverts the blow off into 4 seperate directions. It just sat there and made snow
Old Jul 13, 2003 | 11:59 AM
Wild1's Avatar
Well, we'll see how good their customer service is after Monday... could make it or break it.
Old Jul 13, 2003 | 01:36 PM
Nitrous Crazed's Avatar
It could be a faulty disk.However that is very rare. The safety valve may have been over tighted damaging the blow off cap. This valve just needs to be snuged down.Dont winch down on it to much.
Old Jul 13, 2003 | 04:42 PM
Z28ROC's Avatar
Yep it sounds like it was overtightened. It should be torqued to 14 ft. lbs, if I remember right. It's in the instructions that come with the fitting.
