Bottle pressure
Old Jul 11, 2003 | 10:43 PM
TCAL95Z's Avatar
Bottle pressure
What is the best way to keep bottle pressure consistent in very hot temps.
Or how do you keep bottle pressure from going too high?
The last time I took it out in 100+ temps the gauge went off the scale.
Old Jul 11, 2003 | 10:47 PM
RacinLT1's Avatar
a bottle blanket will help to keep temp's somewhat stable.
on very hot day's,use ice to cool the bottle. I have had to do that numerous times.
Old Jul 13, 2003 | 01:52 PM
Nitrous Crazed's Avatar
This is where a purge comes in.Alot of people think it is just for a cool show.It actually has several purpases.Here they are.
1.Cool shows-LOl
2.To get the air out off the line.
3.To release bottle pressure when to high.
Try to keep the bottle pressure about 1150.
Good Luck
Dave
Old Jul 13, 2003 | 03:18 PM
Hawk's Avatar
1.Cool shows-LOl
Good Luck
Dave
use the purge to release bottle pressure??? That will work but your going to waste lots of precious juice, because the way you are lowering pressure is decreasing the volume in the tank, aka, wasting juice.............
Old Jul 13, 2003 | 06:37 PM
RacinLT1's Avatar
1150? that is a tad high strung.
NX recomends anywhere between 1000-1100 (and 100 is high side).
Each kit is set up for a specific pressure range,too much bottle pressure and you can run lean or lock up a solenoid. not enough pressure for a NX kit and you will run pig rich.
IMO it wouldnt be smart to leave the bottle in the car if you are at work on very HOT days. inside temps of the car get way too hot to even think about keeping pressure reasonable.
Old Jul 14, 2003 | 09:06 AM
Yeah, Im sorry I ment to put 1050 PSI. Yes the purge will let nitrous out but it is the only way to drop pressure with out waiting for the bottle to cool down.
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
weedog
Aug 15, 2015 08:23 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
