The new Nitrous Express NXL system
Old Jul 11, 2003 | 12:13 PM
tbyrne's Avatar
Nitrous Express introduces the "NXL" nozzle with Integrated Rail Technology. This plug-and-play, direct-port nozzle system is available for four, six, and eight cylinder applications. There is no drilling required, no engine disassembly and no solenoids to mount. The entire nitrous system is self-contained in the high-flow fuel rail. Systems come complete with bottle, jetting, custom insulated distribution lines, and all installation hardware. This hi-tech direct port system comes with a wiring harness for a true plug-and-play system.
The picture above will give you an idea what this system looks like but it isn't the actual LS1 kit.
Part Number - 20220-10
Item - LS1/LS6 Nitrous Express NLX kit with jetting for up to 300hp - 10 lb bottle
Price - $1149.99
We are currently taking pre-orders for this system. That can be done on our website or by calling 1-877-4-TBYRNE. This system should be ready to go by the beginning of August.
Tom
Old Jul 11, 2003 | 02:46 PM
got_hp?'s Avatar
is there an LT1 kit?
why is it only adjustable up to 150? can it be adjusted for more?
correct me if im wrong, but don't most people upgrade to a direct port in order to spray more than 200.
the price definetly seems better than a custom direct port setup, if its capable of say a 250-300 shot.
Old Jul 11, 2003 | 03:45 PM
tbyrne's Avatar
That should have been listed with jetting up to 300hp (just corrected it). The LS1 version will be available first. That will be followed by a kit for the LT1.
Old Jul 11, 2003 | 10:39 PM
Wild1's Avatar
I'm waiting to hear about the LT1s. I wonder how much it will lift the fuel injectors which would alter the geometry a bit on the fuel rail. I'm sure they figured that out so it will be exciting to see what happens. Put me on the list for the LT1... I'd like to get some info when it is released.
Old Jul 17, 2003 | 08:58 AM
tbyrne's Avatar
I haven't been able to get a potential release date for the LT1 system yet. I'll post some info when I get it.
Old Jul 21, 2003 | 05:31 PM
MARSTAUT's Avatar
how about a conversion kit from a wet or dry setup?
Old Jul 22, 2003 | 03:25 AM
Wild1's Avatar
As far as I know, direct ports are only wet. Would be interesting though... if you go that route, get injectors and a good pump.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
