- Looking at a 93 Z28
- Hook computer directly into data/diagnostics port?
- 17'' WS-6 rims
- New 99 Z owner!
- Decent Oil Filter...
- msd opti
- Question about oil change light
- Engine pics
- Where can i get this peace for the center console?
- im stumped...anyone?
- TA riding rough ...
- 1995 Z28
- Sport Appearance Package Question
- T-top help
- Engine Flush (in engine oil)
- Grease Lightning cleaner.
- Gas Gauge help.
- T-top weight for shipping
- autocross setup for a 87 iroc
- big problem with big engine(F.I. 496)
- How difficult is it to replace headers with no lift?
- Helms Shop manuals on sale $30 + shipping
- replacing power steering rack
- spare tire air pressure
- trying to track an old car
- LS1 Tail light blinker problems
- no power at scanner terminal
- 93 Front Clip to 03 SS ** NEED HELP**
- bad O2 sensors cause a misfire?
- Does your car get finicky??..
- Should I trade in the LT1 for an LS1?
- header hitting k member
- Speedometer is wayyy off, bad ecm?
- Replacing Rear Hatch Glass
- Going out to buy a battery, what Crankamps should it be?
- Grinding in front end somewhere, im lost. HELP
- Turn signal lense tech
- Tire choices with 16" rims
- Procedure for Bleeding Air from Power Steering System
- Electric Superchargers; do they work?
- Trying to fit my size 12.....
- Door lock gremlins
- need some input on my new car. rare find or not?
- VATS key pellet question.
- GM Labor Times
- what exactly causes O2 sensors to go bad?
- how to build 302 chevy
- cost to get the mara painted
- Carbed 1st gen in 4th gen
- Dashboard/interior lights flickering..
- lt1 tach and fuel gauge?
- Most restrictive exhaust component
- Second time at the track
- Replaced my fuel pump, now the freakin' gas gauge doesn't work.
- It's my T top itself that leaks!
- How long for a hooker aerochamber to break in?
- Fix-a-flat?
- fixed my battery tie-down problem
- Gas Pedal
- does shoebox have a header install guide
- Cars in storage. Going to start it once. How long to burn condensation out?
- Gauge Pod
- alternator brace
- headlight problem
- How do I use a fuel line disconnect tool?
- Stuck Bolt: Need Help
- Unknown Starting Problems
- Whats involved: V6>V8 wiring harness?
- firebird headlights pop up when I turn the parklights on
- Anything wrong with platinum plugs?
- speed vs warranty
- T-Top Leak
- T-TOP lock problems. need matching
- Sponsorship - Body Kit
- Steering Wheel Replacement
- 1st Gen...Which Repair Manuals are Best???
- 98-02 "Glass" Rear end--?
- solution for slow power windows
- 94' Camaro anti-theft rod
- Switched Hot Wire in Console???
- 3rd gen fuel pump
- Problem with floor mats sliding around
- Anybody recognize this paint color?
- fuel problems, any help is welcome
- !!! Need to know what color horn wire is that comes out of steering column on a 91!!!
- Turning off Passenger Airbag in '02
- Just bought '02 SS, have some questions
- What motor to start with?
- My radio shut off and wont come back on. Why?
- How to find out when your car was built
- General question about SS #'s
- Summit Offroad Pipe 96-97
- Emissions, state to state
- Keep foglights on with high beams.
- Who knows the website with the shock/spring replacement kit for under $200?
- LT1 to LS1
- What is the part number for Billestein susp springs?
- Electrical problem lights flickering!
- Fog light mod possibility
- So i cant get my back brakes to work
- How to quiet my Loudmouth down?
- 94 Camaro wire diagrams
- difference between 94-95 z28's?
- anyone have a leaking t-top with a triple gauge pod?
- Headlights on a 93 Camaro cant get out
- A little problem?
- keyless entry rear hatch opening
- T Top leak, help please--83 z28 t top
- My fans come on!!!
- 10th Anniversary
- Door Coming Apart??
- zMax auto additives?
- How do i install a PCV valve?
- What mod would you do next?
- Car hard to start and tach wont work????
- Whistling/humming sound from back of the car.
- LT1 swap for LS1
- Battery is dying everytime I shut it off...
- help, im having a crisis.
- What did I burn out?
- Firebird headlight problem
- Rear Question
- what is the likely cause of my car not starting on the first try...
- Door and window questions....
- micrometer questions...
- Power window motor questions
- New to the board
- Smashed The Camaro
- newb!! - nice site!
- Exhaust video...
- Roll cage/bar Questions for 95z28
- The best shocks for lowered car?
- nor cal maro's lets meet up
- Need some part numbers
- LS1 Center colsoles
- Need Trans
- Ceramic coating a cutout?
- ABS inop light
- afterthoughtsauto.com any good?
- need serouis help LS1 swap
- Foglights question
- Dash top panel removal?
- Fuel pump question
- Suggested tire size
- Let's Try More Z28 Wiper Problems Again
- Calibrate speedo?
- Winter repair and tuneup help
- latest progress on the lt1... check it out
- Hesitation From a Stop
- Fixing cracked center consol
- Cleaning a Block
- 94 z with LS1
- 93 camaro steering cullum what years swap?
- Firebird Headlight Problem
- turn signal problem
- What to do?? Alarm help
- Weather Stripping caughing up???
- 4L60E transmission
- Hello everyone, I'm new.
- Tuning prices
- hyperpac
- Ebay Scammer??? Is it a real 1997 SS?
- question about the M.A.F.
- Allignment Issues
- Fluids
- Poor Brakes = Hard Spot?
- nut size for oil dipstick tube
- Radiator Support Help
- So my car now refuses to start in the cold....
- gmmg
- Steering wheel adjustment w/o alignment
- Has anyone heard this combo yet? -Exhaust-
- What happens if I get pulled over with ORY and LT's?
- Is this a hatch squeek?
- What is this thing called (Maybe bump stop?)
- Bleeding abs unit?
- Carbon Fiber parts
- Happy New Year!!
- Keyless entry problems...
- Installing power windows doors and keyless
- Pass-Key II - Is it really safe...?
- Where to buy the authentic GM repair manuals?
- Which setting should I have my LCAs set at?
- 100w and 80w 9005 9006 headlights?
- Replacing Airbags - What I need
- Deciphering VIN numbers?
- How hard is it to install white face gauges?
- sometimes when i get on it in 1st, the back of my z feels likes its hopping/shaking??
- 4th Generation Vette Rims
- Windshield Mark (not crack/chip)
- Will you still hold pressure with a blown head gasket?
- Is there a definite 5th gen yet?!
- 93 z28: the good and bad
- Camera Mount?
- Do I really need anything else besides springs to lower my car???
- header coatings?
- Hearing some strage Noises
- 17" wheels
- Gm High-tech Mag Went Up To 5.99 Why!!!
- Frame questions
- Question about header wrap....
- 6 or 8
- Stripped!!
- What do you think went wrong?
- What is a fair price for this Z28? Cheap project/parts car
- 2000 Camaro airbag question
- bullet mufflers
- stock exhaust
- Driveabality Questions
- Effectiveness of passkey system?
- What is this called?
- 1999 camaro ss price?
- Anti-Theif
- JB Weld - is it strong enough?
- autozone filter
- Sound deadening material
- Living in Lexington Kentucky
- Rattling noise from rear of car...
- Header On The Way!!
- Would this be an ok deal?
- What's the average milage, before you replace your value train comp.
- What will it take to beat an LS1 SS?
- Will Brand Name LT Headers Make More Power Than Cheap Ones?
- Vacuum Problems
- Driving w/out temp sensor
- Remove decal
- WOT throwing a code- need help
- spark plug gaping, stock motor
- Purple Ice vs water wetter
- Power Rear Hatch?
- Someone help! 1975 Camaro door panels
- Roll cage or no cage
- SIR Question......
- Questions About RS
- SLP question
- fourth gen dash into a third gen
- fitting a 315/60/15 on a 4th gen
- Mechanical fuel pressure gauge - Yes or No
- relocating the battery
- merry christmas!
- LT1 to LS1 T56 parts conversion ??????
- weres the horn
- Service schedule?
- i think i got a thread deleted!!
- Squeaking in the rear hatch ???
- old school sbc in 4th gen?
- Hail Damage. HELP!!!
- 2nd gen guys in here, need help with interior in a 81 Z28
- How to remove power mirror motors?
- Got some extra cash
