94 z with LS1
94 z with LS1
i need help guys, I just purchased a 94 z-28 with a rebuilt LS1 and M-6. At fist the rpm tach was off and now does not move i don't now whats the prob. If any1 does can u please help. Also want to now if i can cut splice the wiring and put an abs connector from a LS1 rear end and a sensor on top of the rear instead of the axel like and LT1 if the ABS INOP light will turn off or do i need a whole new wiring harness for the tach and abs. oh air bag light is also o
n what can i do 2 make it turn off other then scratching it out
Re: 94 z with LS1
Re: 94 z with LS1
I believe you are in big trouble. I know you can't put a 98+LS1 gauge cluster in a a 97LT1 Camaro or firebird because they are wired diff. or set up diff. for the new motor. You might possibly be able to swap in a whole 98+ camaro dash, and it might remedy the problem but its only a guess.
Re: 94 z with LS1
Originally Posted by white/blackss
you would have to wire the whole car with a 1998 or newer ls1 harness.
Re: 94 z with LS1
Or, if everything else is working correctly, then you could just forget the stock gauge and get a nice autometer and put in it.
The stock gauge is notoriously innacurate.
How bout posting up some pics too. I'd be interested to see how the front of the motor was done if the front end of the car wasn't switched over to late model as well...
Dave C.
The stock gauge is notoriously innacurate. How bout posting up some pics too. I'd be interested to see how the front of the motor was done if the front end of the car wasn't switched over to late model as well...
Dave C.
Re: 94 z with LS1
something is different with the coil-per-cylinder design of the LS1 which has a different tach signal than the LT1.
i know you have to run most shift lights in "4cylinder mode" for them to run properly on an LS1.
that's most likely your problem.
