Stuck Bolt: Need Help
Old Jan 14, 2005 | 04:26 PM
SFB767's Avatar
Exclamation Stuck Bolt: Need Help
I'm installing new headlights on my car.
The passenger side headlight assembly went in real quick, but on the driver's side headlight, the little screw/bolt that holds the black frame to the rear of the headlight assembly WILL NOT budge. It turns, but it will not come out at all. I sprayed it with WD-40, but it just turns and will not come out to release the frame from the back of the assembly.
Is there anything else I can try to get this bolt to come out?
Thanks.
Old Jan 14, 2005 | 04:56 PM
blown94's Avatar
Re: Stuck Bolt: Need Help
where in Fl r u? cut the head off worst case scenario. deal with the rest when you get the frame off. try a pair of vise-grips and pull on it as you try to turn it out. if all else fails, a match and a gallon of gas ought to fix it, lol.
Old Jan 14, 2005 | 05:25 PM
LandryP's Avatar
If you can get to the back of the screw give it a few whacks and try again, or apply pressure while turning the screw
A small flat head screwdriver wedged under the head of the screw may work also
Old Jan 15, 2005 | 11:46 AM
kingman109's Avatar
use some PB Blaster- spray it on and let sit for 15 min- spray some more and then try again. . .
the stuff is amazing
Old Jan 15, 2005 | 12:49 PM
hotrod18_69's Avatar
PB Blaster rocks. Saved me many a times. If that doesn't work, as stated above cut the head of the bolt off.
68camaroboltz
Oct 5, 2015 11:56 PM
buggy323
Jul 1, 2015 04:37 PM
sherwinZ28
Jun 6, 2015 08:48 PM
tds1213
Nov 27, 2014 12:55 PM
Lungz
3rd Gen / L98 Engine Tech
Oct 29, 2002 10:17 AM
