Bleeding abs unit?
Bleeding abs unit?
Do you have to do anything special when bleeding your brakes to bleed the abs unit? I want to bleed my brakes and i always though that you have to do something with the abs unit, can anyone verify this and tell me where the bleeding valves are?
Re: Bleeding abs unit?
There are 2 bleeder points on the abs unit itself which needs to be bled first. Then bleed each brake in order of the furthest from the master cylinder. Rear pass. first, then rear driver, then front pass, and finally front driver side.
